Front passenger window stops in the middle
Old Apr 1, 2021 | 11:31 PM
acechess's Avatar
Default Front passenger window stops in the middle
2014 XF - front passenger window doesn't fully go down... stops in the middle... truly appreciate for any suggestions to fix this problem... thank you!!!
Old Apr 2, 2021 | 03:48 PM
IanXF's Avatar
I had to replace window motor when i had a similar problem on the right front window
Old Apr 2, 2021 | 08:19 PM
acechess's Avatar
but the window opens and closes... it just doesn't go down all the way
Old Apr 3, 2021 | 06:24 AM
IanXF's Avatar
Mine being a 2012 I found corrosion in the cables that move the window up and down ,bought part from ebay seller new not oem now it works as it should .By the way its an easy swap took me less than an hour to do complete change
Old Apr 5, 2021 | 12:31 AM
acechess's Avatar
okay... I'll look into that... thank you so much!!!
02silver_x-type
Dec 22, 2014 07:45 PM
JCam
Sep 22, 2014 08:37 PM
Lothar52
Mar 22, 2014 03:22 PM
newuser
Detailing / Car care
Dec 30, 2010 06:24 PM
AngryJagOwner
Oct 20, 2009 08:16 PM
