Fuel cam timing
Old Jan 30, 2021 | 02:46 PM
kansanbrit's Avatar
Default Fuel cam timing
Can anyone tell me for sure if I have put this chain on and timed it correctly please? 5.0L
Old Jan 30, 2021 | 11:01 PM
davetibbs's Avatar
Is your crank locked with the locking tool in that photo?
Old Jan 31, 2021 | 08:56 AM
kansanbrit's Avatar
The only locking/location tool I have replaces the crank sensor and therefore requires a flex plate and bellhousing and then locks the engine with the crank key at 6 o'clock (engine right way up). Is there another tool?
But I believe to time this chain the key needs to be at 9 o'clock. Although I only have this video to go on, see photo at 21 seconds in. Hence my question.
Old Jan 31, 2021 | 01:23 PM
davetibbs's Avatar
The JLR workshop manual sections show where the chains and sprockets should be with the crank locked with the tool at 6 O'Clock (see attached) - INA/Tsubaki is for the two pitches of chain, although I'm afraid I don't remember which is which. I'd reset with the crank locked to ensure the timing is spot on.
Old Jan 31, 2021 | 02:36 PM
kansanbrit's Avatar
Thanks for those Dave, already have the manual. The problem is that the marked links on the chain I have are much closer together than the one shown in the pictures. I can't lock the crank at 6 O'clock because there is no flex plate or bellhousing fitted but the chain is marked differently anyway.
Old Jan 31, 2021 | 03:19 PM
kansanbrit's Avatar
Pretty confident it is timed correctly. I just noticed a third marked link, black so I hadn't noticed it's significance before, and when I wind the crank around so the key is at 6 o'clock the black link lines up as shown in the manual with a gold link by the sprocket dot. Don't need to lock the crank as one tooth is a large degree shift. Thanks for your help.
Old Jan 31, 2021 | 05:21 PM
davetibbs's Avatar
Yep, looks good to me - also compare to mine from photo in rebuild thread, the fuel pump cam is at the same angle (with different colored links in the chain and you can't see the one at the bottom of the crank, lol)
rockwarrior
F-Pace (X761) / C-X17
Oct 19, 2024 04:00 AM
mikega
Oct 14, 2018 01:34 PM
Richard_gib
Oct 21, 2017 01:47 PM
doglegleft2k3
Dec 10, 2010 07:02 PM
kerwint
Jun 20, 2009 03:55 PM
