Fuse box location
Old Nov 6, 2018 | 12:29 PM
Spirit's Avatar
Default Fuse box location
Trunk display on 2010 xf shows open trunk. What is the fuse number and location please.
Old Nov 6, 2018 | 02:01 PM
I doubt there's a relevant fuse.
The likely cause of the message is:
1. incorrect striker alignment/adjustment
2. ajar switch circuit short circuit to ground
3. ajar switch failure
If the X250 is similar to other Jaguar models, the ajar switch will form part of the latch assembly.
Jaguar latches are a frightening cost but the integral microswitches which trigger ajar warnings are usually replaceable with a little ingenuity.
Old Nov 7, 2018 | 07:01 PM
BritCars's Avatar
Most likely the wiring harness that runs into the trunk. The wires eventually break from repeated open and close and it gives open error, sometimes the lock won't open with the button etc
It's in a rubber boot by the right hand trunk hinge. Pull back the rubber and have a look for a broken wire
You can splice it easily else a new harness isn't expensive
hafren
Aug 30, 2023 03:42 PM
wazdude
May 16, 2016 04:38 PM
defnotlurkin
Apr 24, 2016 11:14 PM
tvholden
Sep 12, 2015 11:13 AM
wnlewis
XJ40 ( XJ81 )
Feb 9, 2009 10:47 PM
