Gearbox Drone
Old Nov 27, 2015 | 01:53 PM
Bazz Lambert's Avatar
Default Gearbox Drone
Hi all, I have a 2008 2.7 D XF. I have had it about a year and it has recently developed a slight drone noise and vibration between 1,500-2,000 RPM (seems worse around 2-4 gear change range.
Is this a know fault, or can anyone advise what it might be?
Thanks, Bazz
Old Nov 27, 2015 | 04:14 PM
OzXFR's Avatar
It sounds like you might have a problem common to XF 2.7 and 3.0 diesels, a fuel line hum or resonance.
See this discussion on another forum: Droning at low speed
The fix is not cheap or easy, it involves replacing all three fuel lines.
ionixxx
Sep 18, 2023 04:33 PM
Collector1
Nov 28, 2015 05:12 AM
bmeza001
Nov 25, 2015 04:20 PM
kapows
Nov 25, 2015 01:25 AM
