Hard brake pedal mornings
i have been experiencing a hard brake pedal every morning , looked for air leak without success, check valve looks good,servo looks good , any ideas where I should look
jaguar x250 XF 3ltr diesel lux.
help!! Just feeling that something is going to fail and I’ll loose brake power.
When you park the car, do you keep your foot on the brake pedal once the car is turned off? We had an issue like that in the past and finally worked out that sometimes my wife would park and stay on the phone for a few more minutes, and she kept her foot on the brake pedal so there was no brake boost left
If that's not the case then you've checked the obvious sources. Fluid level ok?
No nothing like that,never ever touch brake after stopping engine, the problem seem to be a leak air to se o but I can’t find i5!! Just wondered if there was a part that fails?
Thanks for your help
Ron��
Ron��
