Hard reset procedure???
hi all,
I am trying to do the hard reset on my 09 XF
I've found a few threads on here on doing so but they are all different and at some point are questioned or told its incorrect.
can some one please tell me the correct way so that I don't fry myself or my car pleaseeeee.......
Digimurda,
Disconnect the (-) and touch it to the (+) The (+) does not need to be disconnected from the battery as long as there is NOTHING connected to the (+) terminal of the battery.. If you are worried about this, just disconnect both and hold them together for 30 seconds, Make sure you take off the (-) first then the (+) and put back the (+) first then the (-).
I have done this many times on my X350 with no ill affects what so ever.
Cheers,
knobby.
Cheers,
knobby.
Digimurda,
Cheers,
knobby.
Cheers,
knobby.
and this all done while the ignition is off and locked correct?
when you say as long as there is nothing connected to the (+) what else in example are you referring to?
I guess ill just take em both off to be safe lol
Opps Sorry, I mean as long as there is nothing connected to the (-) terminal of the battery.
You Can disconnected the (-) side, Make sure nothing else is connected to the (-) of the battery, Put the key in Position 2 then touch the (-) and the (+) leads together for 30 seconds. Just make sure you put the key back to the Zero position or better still just take it out altogether.
I'm so sorry for my typo.
Cheers,
knobby.
Cheers,
knobby.
Cheers,
knobby.
Cheers,
knobby.
in my case my car is push to start, how do i go about putting it back to zero?
As I said before this is how you reset the ECU (at least on the X350) I really don't want to steer you wrong with your 09 XF so hopefully someone on here who is more familiar with the XF will be better informed.
sorry I could not be of more help.
knobby
knobby
