headlight
What type of headlamp do you have? Check the connections!
Well it must be a mechanically weak connection as you mention banging it to make it work. So go back through it all carefully and see if you can determine where your electrical circuit is weak. If not I suggest a dealer visits is in order. If you Have HiD's then there could be a bad connection in the circuit board inside the igniter. If it is a halogen then it could be as simple as a regular bulb with a bad connection to the filament inside the bulb, I have seen that before. Have you tried replacing the bulb?
Either way, if there is a bad connection there will be evidence in the form of melted wires, burnt PCB's or charred components. You just need to look harder!
Fletch44
Sep 28, 2015 02:21 PM
