headlight
Old Apr 3, 2015 | 02:12 PM
Barmi's Avatar
Default headlight
Had my jag for quite some time now it is the 2008 xf model and I now need to bang my front left head light in order for It to come on how can I fix this??
Old Apr 3, 2015 | 04:37 PM
10 XF Premium's Avatar
Sounds like a loose or corroded grounding wire or power wire.
Old Apr 3, 2015 | 05:20 PM
Barmi's Avatar
How would I sort that out
Old Apr 3, 2015 | 05:28 PM
Gpalace's Avatar
Having same type issue...could be Ballast or bulb..mines is intermittant...my mechanic swapped enviorment to see which is failing...suspect ballast. hope this helps.
Old Apr 3, 2015 | 05:42 PM
hlgeorge's Avatar
What type of headlamp do you have? Check the connections!
Old Apr 4, 2015 | 04:08 AM
Barmi's Avatar
Yeah all the connections are in properly non of them were lose.
Old Apr 5, 2015 | 12:51 AM
timfountain's Avatar
Well it must be a mechanically weak connection as you mention banging it to make it work. So go back through it all carefully and see if you can determine where your electrical circuit is weak. If not I suggest a dealer visits is in order. If you Have HiD's then there could be a bad connection in the circuit board inside the igniter. If it is a halogen then it could be as simple as a regular bulb with a bad connection to the filament inside the bulb, I have seen that before. Have you tried replacing the bulb?
Either way, if there is a bad connection there will be evidence in the form of melted wires, burnt PCB's or charred components. You just need to look harder!
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
sdelliott58
Sep 28, 2015 11:21 PM
Fletch44
Sep 28, 2015 02:21 PM
kevinl
Sep 24, 2015 08:25 PM
