Headlight bulb upgrade 2010 jag xfr
Old Jan 4, 2024 | 03:07 AM
Xfrocket's Avatar
Default Headlight bulb upgrade 2010 jag xfr
I was wondering if I should put different bulbs in my headlights because they're not very bright at all that I usually drive around with the brights on because that's usually what other cars look like anyway so I was wondering if someone can give me a bulb number and a place or what I should be doing to replace the originals to make them brighter or maybe like the originals which are super bright I think I'm not sure please help me out with the bulb Choice thank you
Old Jan 4, 2024 | 08:15 AM
clubairth1's Avatar
Community Influencer
Have you checked that they are aimed correctly?
I spent a lot of money and purchased the factory LED headlights for my 2014 XJR. After install they did not seem to work all that well?
But after I re-aimed them it was a night and day difference! Both of my Jaguars have had the head lights aimed too low. How they got that way I am not sure? Maybe from the factory?
Do you know where the adjusters are on your car?
Old Jan 4, 2024 | 08:28 AM
thistle4celtic1's Avatar
I highly recommend switching out the original halogens for LED’s. I just did mine and cannot believe how much easier it is to see the road at night.
if you do switch, make sure you check and see if your low beams are H7 or H11 connection. My owners manual said I needed H7 so I ordered a set of the H7’s, as well as the special connecting rings required for the H7’s, but after removing the headlight I realized my low beams were H11.
The H11’s I ordered were a simple plug and play and required no connecting ring to attach to existing. Here’s a link to the H7 connecting rings if needed…….
https://www.ebay.com/itm/232578802649
As far as the LED bulbs, I’d recommend the type with the built-in fan over the ones that utilize heat sinks. Also anywhere from 35W-55W is ideal, but no more than 55W.
Here’s a link to a great video on switching out the halogens for LED.
rts1021
Jan 4, 2024 08:24 AM
EnjoyEverySandwich
May 18, 2020 04:10 PM
PJ704
Nov 29, 2018 07:36 PM
Robert Grisar
May 19, 2018 07:10 AM
Nosferatu
Oct 27, 2017 04:31 PM
