Help please with tech ecu issues.
Old Jun 29, 2015 | 11:33 AM
crispyj's Avatar
Default Help please with tech ecu issues.
So the story so far....
2008 xf 2.7 diesel
Got home all ok no faults, parked up locked all ok. Whent back a few hours later tried starting her would not start ignition came on and got the following faults.
Park brake fault
Oil pressure low
Dsc not available
Gearbox fault
Then the shift knob raised.
Did some research and replaced the battery no joy. Did a hard reset several times.
I then borrowed my mates snap on diagnostic gear and the following happened
I could not communicate with the ecm , however I could communicate with everything else it seems that they were in error because they could not communicate with the ecm either. I got the following code.
u0100 power train control module a.
Any ideas ?
Thanks.
Johncy2000
Oct 2, 2015 01:05 AM
asleach2889
Oct 1, 2015 01:53 AM
dmatthewman
Sep 30, 2015 10:10 AM
dansxj6
Sep 28, 2015 08:02 AM
