High mileage 5.0 supercharged engines
Old Sep 29, 2025 | 02:12 PM
  #61
bmcinsd's Avatar
Originally Posted by GaiaXF-V8S
185K miles on my 5.0 Supercharged, still going strong. Check your oil often, oil starvation is always an engine killer. It is especially important with this engine. Make sure your oil level is always in check as there is no low level warning. It is my belief that oil starvation is the most major culprit in the tensioner/guides failing on the 10-13 engines.
Revised parts will definitely prevent the chain from moving around too much, but oil starvation, IMO, is what is taking them out. I have had rattle from the timing chain on warm restarts since 86K. Since it is such an expensive fix even if you do it yourself...I have chosen to increase my engine RPM on warm restarts and allow the tensioner to regain oil pressure. Increase engine speed to 1500 for 20 to 30 seconds before your drive and the engine will quiet and run fine.
I am certain this coupled with watching my oil level like a hawk, is the only reason the tensioner/guides haven't failed yet. I have also been down the drag strip over a dozen times and I generally drive like I stole it most days. Hope this helps some of you guys approaching high mileage. I have many more recommendations for anyone interested, but I'll wait until someone replies so I know I am not just talking to myself!
Bringing this thread back to life!!… Ok, after my engine out repairs for broken timing tensioner issues (and lots of maintenance work), I’ve been relatively trouble free for the past 89k miles. As long as you keep routine oil changes at 5k and check fluids often, the car has been reliable. Haven’t been mashing the pedal since the engine out, which helps. Also, if you hook the car up to a daily battery charger, so many gremlins disappear. Currently at 189,000 miles.
Old Oct 1, 2025 | 02:10 AM
  #62
2010XFPushBrakeHarderToStart's Avatar
Not even the occasional WOT to clean out deposits in the combustion chambers?
The ol' Italian Tune Up?
Old Oct 1, 2025 | 03:51 AM
  #63
ComptonCat1's Avatar
Default 2010 xfr supercharged
Originally Posted by ashbypa
I am curious to see how many 5.0 supercharged engines are past the 100K mark?
My XFR is a daily driver and I am adding miles faster than I thought I would.
Any high(er) mileage cars out there?
Andrew
150000 miles parking brake doesn’t engage & speedometer sensor code besides that run good
Old Oct 1, 2025 | 10:55 AM
  #64
bmcinsd's Avatar
Perhaps I run it up to 5k rpm 😊.. Put in fuel additives occasionally.
Roarer
Mar 9, 2024 02:34 PM
Jorge Velarde
Dec 26, 2018 11:16 PM
Wayne1357
Sep 25, 2018 02:31 AM
hades281
XF (X260)
May 28, 2018 08:55 PM
Crcoop
Feb 12, 2015 02:23 AM
