high pressure fuel line coupler leak
Old Aug 27, 2025 | 08:52 PM
phil51's Avatar
Default high pressure fuel line coupler leak
2013 Jaguar XF 3.0 AWD supercharged- The high pressure fuel line coupler on the LH side of the engine by the firewall is leaking. It is the front male part that is seeping. The female o-rings are fine. Is there a repair for this? Does anyone know the name of this part and/or have an O.E. part number? Thanks, Phil
Old Sep 2, 2025 | 02:45 PM
clubairth1's Avatar
Community Influencer
Good car info so thanks for that. But can you post a picture of what your problem is?
These DI engines have very high fuel pressure and the SS fuel lines come up on the RH side of the engine to the fuel pumps then onto the engine. These seal with metal to metal seals and no O-rings?
Nothing attached on the firewall?
Do you mean the plastic tubing on the LH side of the engine?
Old Sep 5, 2025 | 05:01 PM
kansanbrit's Avatar
I think you mean the low pressure fuel coupling....
TylerDurden
Apr 24, 2024 10:57 AM
asdf
Apr 23, 2024 12:15 AM
odpuskas123
Nov 16, 2023 10:22 AM
dh53
Apr 5, 2022 01:15 PM
hdsg
Jan 6, 2014 04:04 PM
