Hissing noise and oil leak
I’m learning from the ground up so please bear with me. I’ve recently had a cracked inlet manifold which leaked a fair bit of oil, I’ve had it fixed under warranty, but I’ve noticed a loose connection since the work was don. I’ve no idea to this pipe, but the connections loose, and its leaking oil, I think, just wanted to know if it’s associated with the manifold inlet? Any advice?
Surprised no-one responded to this.
The problem was Hissing sound in engine bay and some exhaust fumes in cabin through air vents,
The pipe in question was the ERG valve on the return into the air intake system, the clasp for the hose had come loose,
simply tightening it up solved the problem.
EsRay
Nov 25, 2017 01:14 AM
daboss085
Nov 14, 2012 06:00 PM
daboss085
Nov 7, 2012 08:45 PM
