How to change serpentine belt
Old Jul 27, 2014 | 12:32 PM
leadfoot4's Avatar
Default How to change serpentine belt
I have a 2009 XF Luxury Model, and although the mileage is low, the car IS now 5 years old, and I'm a maintenance freak. I picked up a new serpentine belt, and went to install it.
I previously owned an "XF cousin", a Lincoln LS, which I thought I swapped the belt out from underneath the car, therefore I thought the XF would be the same. Turned out I was wrong, as I removed the front air deflector, expecting to access the belt, but couldn't.
I guess there's access from the top, but I'm not sure about what components I'll have to remove. Any input would be greatly appreciated!
TIA!
Old Aug 2, 2014 | 06:23 AM
leadfoot4's Avatar
bump....
Old Aug 2, 2014 | 10:58 AM
lotusespritse's Avatar
If you are a DIY maintenance freak, you should definitely invest in a subscription to the shop manual TOPix or AllDataDIY so you don't have to guess, and guess wrong, on the right way to do things.
silkcat
Jan 18, 2025 04:29 AM
mrplow58
Jan 21, 2024 05:53 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
