How to remove A Pillar interior panel?
Old Jan 10, 2019 | 11:52 PM
carzaddict's Avatar
Default How to remove A Pillar interior panel?
how do I pull off the interior panel for the driver side A pillar? Last year the wire for the electric heated windshield was heating up and melting the plastic, causing smoke, I had it taken care of but I suspect the similar is happening again because I smell a sweet burning smell.
Is it just a pull off? And specific way I should do it?
Old Jan 11, 2019 | 12:01 AM
OzXFR's Avatar
Flip/lever the airbag cover off (the little panel with "airbag" on it).
Underneath is a single screw (Philips head IIRC), remove that screw.
The panel then just pulls off, but some levering with a trim removal tool usually helps.
Old Jan 11, 2019 | 07:48 AM
carzaddict's Avatar
thanks, will try that today.
Old Jan 11, 2019 | 03:51 PM
OzXFR's Avatar
I forgot to add, you need to pull the door opening sealing strip (rubber) away from the A-pillar panel first, it simply pulls off and you push it back on.
Old Sep 27, 2020 | 09:49 AM
reece waller's Avatar
Hello i have the same problem and am wondering how you fixed it and what part is needed thank you for any help
Old Sep 27, 2020 | 09:54 AM
kage7
Sep 7, 2018 08:19 AM
jomo
Aug 22, 2014 04:51 PM
jagclaude
Jun 2, 2012 03:11 AM
locorebob
Jul 17, 2011 08:17 AM
dwclapp
Dec 20, 2010 01:35 AM
