I have a problem with my Jag, Many faults comin up
Old Nov 30, 2023 | 07:14 PM
sekhardevineni3's Avatar
Unhappy I have a problem with my Jag, Many faults comin up
Hi everyone, I got a issue with my Jaguar xf 2011 3.0 Diesel, There are many faults popping up when reader is connected no mechanic is giving me a right solution if any one can please please have a look and help me.
Engine control - 7BA / Diesel EDC 17CP11
Status :P006A - Intake manifold pressure / Air mass meter.
Error Message : Malfunction. Historical fault.
Status :P00BF - Air flow meter (bank 2) / Air mass meter (Bank 2).
Error Message : Mechanical fault. Historical fault.
Status :P00BD - Air flow meter (bank 1) / Air mass meter (Bank 1).
Error Message : Mechanical fault. Historical fault. Status :P2269 - Water in fuel indicator.
Error sporadic. Status :P2459 - Diesel particulate filter: Frequency of the function <Particulate filter regeneration>.
Error Message : Too few signal changes
Error sporadic. Status :P2452 - Particulate filter: Exhaust gas differen. pressure sensor 1.
Error Message : Installation error.
Error sporadic. Status :P2192 - Lambda control: Control adaptation of upper load range (bank 1).
Error sporadic. Status :P22D2 - Turbocharger solenoid valve Turbine inlet.
Error Message : Specified position not reached.
Error sporadic. Status :P22CF - Turbocharger solenoid valve Turbine inlet.
Error Message : Component sticking. Error sporadic
Thanks,
Sekhar
UK
Old Dec 1, 2023 | 03:34 AM
Welcome to the forum Sekhar,
What prompted you to put a code reader on the vehicle - was it a specific engine fault and the instrument pack MIL illuminated or just curiosity? There's no need to deliberately go looking for trouble with a Jaguar - in time trouble will find you.
Whenever I put SDD (Sympton Driven Diagnostics) on a Jaguar, it's unusual NOT to find several historic codes recorded. Yours is not an especially long list. The vast majority will have been caused by temporary out-of-range signals to sensors and aren't a problem. A frequent cause of this is a partially discharged or failing battery. I presume you haven't used Jaguar SDD or the date and time or mileage of each code would be shown depending on the how the diagnostic session report is configured.
Now you have the list of codes, you could clear them, run at least two drive cycles and see if any are recorded again. My approach is not use diagnostics on a vehicle unless there's a fault and then not to clear codes unless the MIL is illuminated as this is often the only way to turn it off.
I see you began this question in the UK Region forum before being redirected to the Model forum by one of our members. Please read the guidance for new members ( https://www.jaguarforums.com/forum/n...ned-up-241802/ ) which answers many of the most frequent questions about getting started.
Old Dec 1, 2023 | 12:33 PM
clubairth1's Avatar
Community Influencer
Follow Graham's advice. We want current fresh codes only!
Also note the US got no Diesels and this forum is mainly US people. So we have zero experience with your engine.
I recommend to post on the UK Jaguar forum as most of the guys over there do have Diesels.
UK Jaguar Forum
sekhardevineni3
UK & Eire
Dec 1, 2023 03:37 AM
Fishface
May 10, 2019 09:56 AM
Fishface
May 10, 2019 09:01 AM
L Bower
Nov 18, 2017 10:53 AM
WillyWheels
Aug 12, 2012 11:02 AM
