Intermittent Starting Problems
Old Dec 8, 2014 | 07:56 AM
DaveBailey's Avatar
Angry Intermittent Starting Problems
Just bought a XF 58 plate, 59K on the clock. No problems initially, started first time every time however, now experiencing intermittent starting problems. Some times it will fire up first time, other times it turns over for ages before it starts, hot or cold. Stopped for a brief moment the other day to dash into a shop and low and behold she wouldn't start on my return despite the fact it started first time on this particular journey. Took it to a dealer who couldn't detect ant fault, they replaced the fuel filter but to no avail.
Any ideas. Beginning to think I could have spent good money on this purchase elsewhere.
Old Dec 12, 2014 | 11:00 AM
Titan44's Avatar
Having the same issue. If my key fob hasn't been inserted, it will sometimes say that it's not detected (other times it will start with no issue). But even when I insert the key fob, the car won't start.
I have a battery that's less than 2 years old, and an alternator of the same age from a previous issue where the old battery was leaking acid onto the alternator. If anyone has any ideas, it'd be appreciated. This is for a 2009 XF, btw.
Old Jan 12, 2015 | 02:37 AM
Bigg Will's Avatar
These car must have a good too notch battery, so if yours is in anyway suspect that's where I would start.
Old Jan 12, 2015 | 09:56 AM
lotusespritse's Avatar
The battery is in the trunk, and the alternator is under the hood. How did the acid get from the trunk to under the hood?
Old Jan 12, 2015 | 01:10 PM
tbird6's Avatar
I was wondering about that too?
Old Jan 12, 2015 | 01:14 PM
I am guessing this is one of those creative explanations a mechanic gives to someone not so mechanical as to why they need to be ripped off by having work done that doesn't need doing.
Old Jan 14, 2015 | 10:29 AM
whyhellothere's Avatar
I remember reading something from the manual or here, where if its cold, and you get in the car, you have to wait a certain amount of time before the push start turns the engine, or it resets the timer..
or wait to see a blinking start/stop?
Ill post it here when I run in to it again.
It frequently happens to me, and I just chill wait a minute and try to start again..
Old Jan 14, 2015 | 08:26 PM
Titan44's Avatar
Sorry, I meant the starter solenoid.
Old Feb 12, 2015 | 10:09 AM
DaveBailey's Avatar
Smile Problem Solved
Thanks Guys for all the solutions.
fault found - turns out that if diesel is not presented to the injectors at a set pressure then the injectors don't open and she won't start. With mine th initial pressure was always low at start and would build up to eventually start after turning over for ages.
The culprit was a faulty high pressure fuel pump. Diagnosis and replacement cost £1200 !!
Old Feb 12, 2015 | 10:50 AM
sparkenzap's Avatar
WEll, the starter solenoid is not in the trunk either, is it?
Old Feb 12, 2015 | 12:25 PM
tbird6's Avatar
Yes that explanation did not help?
Old Feb 17, 2015 | 08:55 AM
DaveBailey's Avatar
Agreed. But that was Titan44's explanation not mine. I'm in the clear, I know full well where the solenoid resides.
Happy Times
JarodL
Mar 7, 2024 01:39 AM
alpecsa
Sep 7, 2015 11:55 AM
tberg
Sep 7, 2015 07:32 AM
David Thompson
Sep 3, 2015 07:48 PM
laserguy
Sep 3, 2015 02:02 PM
