Irregular Braking due to Engine downshift?
Old May 27, 2015 | 12:01 PM
tbird6's Avatar
The lurch is a result of the ZF "Mechatronic" Transmission. This means the transmission does not free wheel when you come to a stop as all the older American made 3 speed transmissions do.
So you don't have that smoothness when coming to a stop and some people can feel it better than others and software plays a big part in how the transmission downshifts when you come to a stop. That last shift from 2nd into 1st is usually where we feel the lurch.
As was posted above they seem to have fixed this on the newer 8 speed ZF's.
Here is a bit on the 6 speed ZF that maybe you have not seen before?
Old May 27, 2015 | 08:48 PM
jagular's Avatar
This ZF does not shift into first as you come to a stop. The software causes the tranny to start off in second unless you hit the gas hard.
Old Aug 21, 2016 | 08:42 AM
Rick 1957's Avatar
wow I'm happy to come across your thread!! i just acquired a 2001 XJ8 VDP. When I come to a full stop & leave without a foot tromp. It is most apparent that a mild thump occurs but again only in certain scenarios. your saying it is somewhat common & that to me is a relief. No codes indicate driveline/gearbox issues other than abs trac not avail. i'm working on now to clear
Old Aug 21, 2016 | 09:32 AM
Mikey's Avatar
You've got a different transmission than the models being discussed above. Might want to start a new thread in the XJ8 section.
Old Aug 21, 2016 | 09:41 AM
Rick 1957's Avatar
Thanks Mikey, Cheers!!
Old Aug 24, 2016 | 05:10 AM
Nillamb's Avatar
Does this apply across all models? My R shifts into first (in all settings, including "D", except for winter mode), when decelerating down to about 2 - 3 mph. I am certain it is first, not second, as the revs rise very quickly when subsequently setting off and confirmed by accelerating slowly, feeling a change (about 5mph), then going into manual mode and being in "2".
My car is a "VX" registration, or a so called "engineering car" (very early release). I wonder if they changed it after that.
On topic - I also had "the lurch" into 1st as described above. I took my car to a ZF authorised dealer (not a Jag dealer). They serviced the gearbox and rest the software and it's super smooth now, 100% cured the lurch.
Old Aug 24, 2016 | 11:28 AM
webshark's Avatar
How much was service ? Where you located? I wouldn't mind know a ZF dealer out here in Los Angeles for same purpose.
Old Aug 24, 2016 | 01:07 PM
  #28
Nillamb's Avatar
I'm in Scotland, the ZF dealer is in Glasgow. But I'm guessing that's a long way for a gearbox service ;-)
Cost was £330.
Old Aug 24, 2016 | 03:45 PM
Bigg Will's Avatar
Most automatic transmissioned performance cars introduce some sort of engine braking during deceleration if the driving parameters allow, (ie your not in a corner or in snow mod etc.) My XFR has done it from day one, so unless yours is severe my guess is it's normal.
Forcedair1
Sep 8, 2025 01:57 PM
JarodL
Mar 7, 2024 01:39 AM
PMKimpton
Aug 3, 2019 08:22 PM
obwoodie
Sep 3, 2015 07:45 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
