Jaguar XF 2.2l Diesel Dec 2013 Wipers Faulty in Rain
Hi
Jaguar XF 2.3 l Diesel Dec 2013 has developed a weird wipers fault. In the dry the wipers work fine (though I obviously don't do this- just done briefly to test using the screen wash button). After it rains, and ONLY after it rains, they will start working when switched on, wipe a few times, then stop at any odd position on the screen, and will not park correctly. If I switch the wiper switch off and then on again they will do the same cycle but again stop after a few wipes. They will do this for THREE times only - after this they will only work if I stop the car by turning the ignition off, then re-starting the car engine. It then repeats the three cycles only every time and then I have to re-start yet again.
It is infuriating so I would be grateful for any help please. I have Googled with no result but I am sure some expert out there will know exactly what this fault is. Thank you
Can't find a decent pic of fuses and functions online so can anyone help with location of this screenwash fuse?
Ties in with the heavy frost which caused the issue in the first place - probably affected/damaged the pump etc
jage73
16
Jan 10, 2021 03:45 PM
