2005 X350 ws wipers park in mid wind shield
Old Jul 4, 2019 | 05:42 AM
jage73's Avatar
Default 2005 X350 ws wipers park in mid wind shield
The wiper switch has a number of notches or switch positions. It frequently happens that the wiper blades will park in mid screen, rather than "lying down". I have no idea whether the fault lies with the ws wiper motor, or the switch. Does anyone have any experience with this, because I don't understand this at all !?
Old Jul 4, 2019 | 02:06 PM
V8driver's Avatar
Will they move again if you play with the stalk/hit the screenwash? Wiper motors and linkages can go but in my experience (with other cars, mostly Fords) the stalk tends to go first as they are usually copper to copper physical connections that wear out or tarnish
Old Jul 5, 2019 | 07:06 AM
abonano's Avatar
+1 on stalk.
Old Jul 5, 2019 | 04:25 PM
JoeDredd's Avatar
I had a similar problem on a MK3 Ford Mondeo, on normal wipe it was OK but if it was on rain sensing or intermittant the park position would slowly creap up the windscreen. It would get to the point that the wipers would stop working and flicking the wipers back to normal wiping would fix it until the process started again. I tried a stalk and motor but neither fixed it, I never did get it sorted.
Old Jul 5, 2019 | 04:44 PM
BlackKat's Avatar
Check the relay, there are two one for speed and the other for stop.
Old Jul 9, 2019 | 04:52 PM
ChrisMills's Avatar
I don't have a fix, but report this does happen intermittently with my 08 X358. There appear to be 2 park positions, one correct and one mid-screen.
When it happens, all the intermittent wiper settings are unuseable really, however one can pull the wiper stick back (single wipe) until the wiper is past the "intermediate" position and it will then park normally.
Much more worrying, on my classy Jag, is that every time it happens my wife just bursts out laughing...
(A search suggests possible earthing wire problem perhaps near the headlights, though I haven't got that far yet)
Old Jul 10, 2019 | 06:53 AM
jage73's Avatar
Thanks to those who have responded to my question. I have now juggled with the wiper controls and its now functioning properly again. However I am not at all clear what particular combination of switch positions cause the problem. The comment that its a goofy intermitent grounding problem is often the cause of strange behaviours !!
Old Jul 10, 2019 | 07:27 AM
Wingrider's Avatar
Kind of amusing in a way, not your issue at all.
Just that so many people try to get them to park midway.
When its time to change the wiper blades.
Old Jul 11, 2019 | 11:44 PM
ChrisMills's Avatar
Originally Posted by Wingrider
Kind of amusing in a way...Just that so many people try to get them to park midway. When its time to change the wiper blades.
Heh-Heh. Someone suggested you could get to mid-park by the single-wipe with ignition on-engine off. But they sure made a fool out of me when I needed it. They must have been suffering this fault and not realised it. :-)
Old Jul 12, 2019 | 02:01 PM
Wingrider's Avatar
The only cars wipers that function this way, i've ever seen or owned.
Old Jan 9, 2021 | 01:38 PM
Arno Vermeer's Avatar
where can I find the relay, on the motor itself?
Old Jan 9, 2021 | 05:41 PM
Snowcone551's Avatar
My 2008 X358 does the same thing. When on intermittent, they will occasionally park in the middle of the windshield, it defs makes passengers laugh- lol.
Others on the forum have reported the relays for the wiper system can go bad and replacing them may cure the problem. I have not gotten around to replacing the relays yet but it makes since as if the relay gets stuck or the power switches off they will park.
Very annoying when it does happen
Old Jan 9, 2021 | 06:59 PM
Wingrider's Avatar
Look here
Wiper problems - stops & starts
On page 3
Old Jan 9, 2021 | 08:45 PM
I think you forgot the link
Old Jan 10, 2021 | 12:32 AM
Where can I find the relais that's responsible for the 0 position of the whipers
Old Jan 10, 2021 | 02:40 PM
Wingrider's Avatar
Look here
Auto Wiper Return Fail RESOLVED
Reply Subscribe
Rate Thread
#1 Report Post
Old 06-05-2014, 05:40 PM
Muddybear's Avatar
Muddybear
Muddybear is offline
Old Jan 10, 2021 | 03:45 PM
Look here
Reply Subscribe
Rate Thread
#1 Report Post
Muddybear's Avatar
Muddybear
thanks,
Duke85
May 23, 2020 04:50 PM
XJDanny
Jul 5, 2019 03:50 PM
Seann1212
Feb 6, 2018 11:32 AM
andrew lowe
Mar 30, 2013 04:36 PM
Mark Saggese
Feb 6, 2013 08:17 AM
