Jaguar xf 2.7 d 2009 engine problem
Old Dec 18, 2022 | 02:40 AM
Jaguar xe's Avatar
Default Jaguar xf 2.7 d 2009 engine problem
Hi,jaguar xf does not start, it starts for a while (5sec) and dies. brake cleaner works, fuel pump checked, also injectors checked, air sensors also changed.
Old Dec 18, 2022 | 11:17 PM
Jaguar xe's Avatar
I went to the store and when I came back it wouldn't start.
Old Dec 20, 2022 | 03:43 PM
Bigv's Avatar
Fuel filter checked?
Old Dec 20, 2022 | 11:13 PM
Jaguar xe's Avatar
Yes it IS checked
Old Dec 21, 2022 | 12:17 AM
Bigv's Avatar
Low pressure fuel pump checked?
Old Dec 21, 2022 | 01:34 PM
Jaguar xe's Avatar
yes it IS. and diagnostics dont show anything.
Old Dec 22, 2022 | 01:17 AM
Bigv's Avatar
This sounds, very much, like a fuelling problem
I would take the hose off the fuel filter that goes to the high pressure pump and stick it in a bucket of diesel to see if it starts and runs. While plugging up the filter outlet…
This would rule out everything from the h/pressure pump backwards
Old Dec 23, 2022 | 12:12 PM
Jaguar xe's Avatar
Yes pressures IS ok and fuel IS Coming to filter and going to injectors
Old Dec 23, 2022 | 02:01 PM
Bigv's Avatar
What diagnostics tool are you using?
Old Dec 23, 2022 | 02:19 PM
Bigv's Avatar
And what pressures are you seeing on the fuel rail?
Old Dec 24, 2022 | 07:36 PM
Jaguar xe's Avatar
Fuel Pressures IS 45psi,where Are modul what i need to check(maybe water damage),
Old Dec 25, 2022 | 04:25 PM
Bigv's Avatar
The pressure is very low
Is that when you’re cranking the engine?
If it is, it looks like you have a problem with the high pressure pump
Old Dec 31, 2022 | 02:29 AM
Jaguar xe's Avatar
how much to pressure should be
Old Jan 2, 2023 | 01:18 AM
Bigv's Avatar
If you’ve got 45psi in the fuel rail, there MUST be a fault code
Take it to a garage
There should be 1000’s of psi
Ole Jacob Veiergang
General Tech Help
Jan 27, 2020 04:20 PM
Nick Cowger
Apr 24, 2019 09:16 PM
tomwilcox
Oct 15, 2014 06:41 AM
