Jaguar xf 2009 v6 3.0 HEADUNIT KEEPS ACTING ON ITS OWN
Old Mar 14, 2021 | 06:38 PM
Jordan Garda's Avatar
Default Jaguar xf 2009 v6 3.0 HEADUNIT KEEPS ACTING ON ITS OWN
Hi there follow car owners
I picked up this lovely jag two weeks ago, but sadly the head unit keeps changing audio source mainly at a steady pace on its own. This is very annoying when I'm trying to use the aux. But I have tried with no Bluetooth devices and aux devices in car and still does it. Any help would be much appreciated the steering wheel and head unit source button are both functioning properly. Sometimes it even chnages to the phone menu?
Old Mar 14, 2021 | 06:39 PM
Default Jaguar xf 2009 v6 3.0 headunit keeps acting on its own.
Originally Posted by Jordan Garda
Hi there fellowcar owners
Old Mar 14, 2021 | 07:06 PM
BritCars's Avatar
Sounds like a scratched or damaged touchscreen? Causing it to think it's being pushed
Might start by giving it a careful and thorough clean. And see if that helps
Also check battery is fully charged
Old Mar 14, 2021 | 07:10 PM
will try a good clean in the morning it looked clean.
Old Mar 14, 2021 | 07:34 PM
Battery is fully charged and if I change put the screen into screen save rit still manages to change. Cleaned and still same issue. Only thing that works is turning off the audio by pressing the volume knob
Old Mar 15, 2021 | 12:55 PM
anyone got any ideas?
Old Mar 16, 2021 | 02:34 AM
litteredwithfaults's Avatar
The phone menu thing in conjunction with source points to the steering wheel buttons that are grouped together on the left panel. They are either degraded in some way or the clockspring is on its way out, then you would also start to see every other control on there causing issues like the airbag light, volume not working sometimes, cruise error etc
Old Mar 16, 2021 | 01:37 PM
Thank you for your reply.
This is all on the steering wheel electronics??? or on the headunit left side?
Old Mar 17, 2021 | 07:24 AM
Steering wheel, the buttons contacts could be shorting. The thing that transmits the button signals as the steering wheel rotates is called the clock spring, but you would be seeing other stuff showing errors so it should be just the buttons.
Old Mar 17, 2021 | 07:46 PM
BritCars's Avatar
Perhaps you can disconnect the current buttons on the left side of the steering wheel and see if the issue persists?
Old May 14, 2021 | 12:25 PM
Car keeps randomly calling and changing sources this is why im replacing
I have plugged it in to diagnose machine and come up with amplifier faults. i am planning to replace amplifier but how is calling using that?
My mechanic doesn't think its the clock spring.
Is it more likely to be the information control module according to your diagram because there is no call function on the radio?
Old May 14, 2021 | 12:52 PM
chris.schneider's Avatar
Before trowing parts at it I would try out Britparts suggestion and disconnect the left steering wheel controls. Simple to get at, remove the torx screw from behind the steering wheel to remove the shift pads, then you get access to the torx that holds the control. Pull out and disconnect the cable. If it keeps changing sources your issue is somewhere else.
Chris
Old May 19, 2021 | 03:40 PM
Replaced icm and amp and it all works thamk god. Thanks for ur help!
Davis
XF (X260)
Mar 9, 2021 04:48 AM
Jakub Sobotka
Mar 21, 2020 04:38 PM
Chandoo
US Northeast
Sep 25, 2018 08:55 PM
Denisaok
UK & Eire
Jan 13, 2016 07:04 PM
greatoldone
Audio/Visual Electronics
Oct 7, 2011 08:10 PM
