Jaguar XF air vent Problem
Old Apr 7, 2020 | 12:17 PM
Kurt Iseli Jr.'s Avatar
so i have found the Problem it was the PTC Heater. When i unplug the ptc Heater everything is working.
now is my question for change this part is very complicatet. So you say i dont need this part and can go to a garage and they program it out?
Originally Posted by Robinus
Neither. You want to disconnect the auxiliary electric heater. On my 2009 XF 3.0 diesel, at the heater, a small green/white wire goes to it. Disconnect that. Your wiring may be a different colour. If this works, go to your garage & get them to program it out too.
I downloaded both the files above but couldn't open them & I can't find a decent diagram for you as I'm doing this on my phone. The S-type had a diesel powered Webasto auxiliary heater. With the XF range they changed to an electric one. It's purpose is to help heat up the coolant quicker in cold weather, so the engine & heating warms up quicker. Do a Google search for 'Jaguar XF auxiliary electric heater' or ask your garage. Mine was easy to get to, but I have a different model.
Old Apr 7, 2020 | 12:29 PM
User 42324's Avatar
PTC ?
Old Apr 7, 2020 | 01:00 PM
PTC ?
This Part is PTC Heater
Old Apr 7, 2020 | 01:26 PM
User 42324's Avatar
That looks like the part but that number didn't match anything I could find.
I unplugged mine & ran with no problems for about a month; I then learned it could be programmed out & had it done. That was nearly 3 years ago.
Their primary use is for cars in countries where it gets REALLY cold. Think Norway, etc.
Glad you got to the answer, my one took over 5 weeks of looking & only found it as there was a multimeter attached when it happened to spike. So we'll call that 20 euros 😁😁
Old Apr 14, 2020 | 09:15 PM
fivel's Avatar
Is it part 21 from this diagram?
https://parts.jaguarlandroverclassic...63-heater.html
Old Apr 15, 2020 | 02:44 AM
yes is thw Part 21 in the Diagram. I have unplug the red and Black Cable and everything works now.
Originally Posted by fivel
Old Apr 15, 2020 | 04:05 AM
User 42324's Avatar
Yes, that's the part. On my 3.0 D it's a green/white wire.
Old Apr 15, 2020 | 05:35 AM
  #28
i have unplug a big Red and Black one i send you a picture.
Old Sep 27, 2020 | 12:48 PM
Daniel JGR's Avatar
Hello, i have this problem with mai jaguar xf 2.2 2012 , where can i find this plug to disconnect it?
Thank you !
Old Oct 26, 2020 | 07:52 AM
  #30
Daren's Avatar
Default Location of red black wire
hi is this red and black wire in the passenger foot well
Old Oct 26, 2020 | 09:35 AM
  #31
User 42324's Avatar
It's only the passenger side in a right hand drive car, but yes, it's the left hand footwell.
It is located to the bottom left of the entertainment unit/radio etc.
Uncover the material underneath the dash in the left hand foot well and it will be up to the right. The big red and black cables are obvious once you see them.
Old Oct 26, 2020 | 10:46 AM
  #32
Daren's Avatar
ok thank you I will look tomorrow as iv no heat at all now
Old Mar 9, 2022 | 09:04 AM
  #33
wallett's Avatar
This worked for me I just unplugged the red one what happens now with the heaters will they stop working again eventually if I just leave it unplugged thanks
Old Mar 9, 2022 | 03:02 PM
  #34
User 42324's Avatar
If that's all you unplugged then no. It's a different part of the car's systems that interferes with the a/c operation when it goes bad.
Old Dec 24, 2022 | 11:53 AM
  #35
Pmackin's Avatar
Default How do I disconnect the PTC heater?
How do I disconnect these red and black connectors?
hi! Same fault as OP. How do I disconnect these two connectors which from reading this thread power the PTC heater? They don't seem to just pull out and can't see any obvious tabs to push or pull? TIA
Old Apr 10, 2023 | 01:49 AM
  #36
Mircea's Avatar
Hi Robinius , i want to ask you a question , after you disconect the aux heater your air conditioner still blow cold air ?thanks
Old Apr 14, 2023 | 12:48 AM
  #37
cookie311's Avatar
Default 08 xf x250 ptc
hi guys
what type of garage would program out etc ie would it auto electrician or air con guy as my local garage has no idea
cheers
Old Jul 10, 2023 | 06:36 AM
  #38
apono's Avatar
on my 3.0 D I had this exact same problem, and disconnecting the red plug has helped me. But I could not see the continue of this topic. What way do we fix the pre-heater? Who can programm it? No replacement is needed?
Old Aug 11, 2023 | 05:29 AM
  #39
gillissen's Avatar
Exclamation vent problem xf
Same problem on my Jag 2012 2.2d
Thx to this thread problem resolved
It's on the left side in a left or right hand drive car,
Take away the blue latch with a n isolated screwdriver then gently pull out the copper +plug no need to do the negative black cable
Isolate it immediatly whit tape.
Thx to all
Old Nov 1, 2024 | 02:58 PM
  #40
blackcats. 1's Avatar
Hello my name is Kurt. And life in spain. I will thank everyone that can help me. And im happy to be here in this forum. So i want to explain my problem, and sorry my english is not perfekt. My car is a Jaguar XF 2.7d and my problem is with the ventilation. They don't work like they need. Sometimes they works perfect but very less so like every 2-3 months is working everyting but only for 2-3 hours. and then is the problem the 4 ventilations are open all the time, i can change the temperature on the display but the air temperature is not chaning. i can change it on the display where i want that come the air. But the air come only on the feet. Can somebody help me what that can be?
thanks a lot for your help
under glove box pull Pannal off two bid connectors red and black pull them off tape them up disconnects the pre heat it worked for me on my XF 3.0 2013
