Jaguar XF Ballast Installation location and review
Old Jan 7, 2019 | 01:49 PM
hemXF's Avatar
Default Jaguar XF Ballast Installation location and review
Hi all, I am pretty new to jaguar cars and I have a 2013 Jaguar XF RWD 6 cyl which have a burnt headlight on passenger side. I was told that ballast is burned out as well. So i am trying to replace both.
Can any one let me know where exactly the balast is located?
I am trying to get Dorman® - OE Solutions™ Xenon Headlight Control Module 601-066 ballast. Does any one used it If yes. Is it worth 140$ for this Ballast?
Thank you.
Old Jan 7, 2019 | 02:34 PM
davetibbs's Avatar
The balast is located under the headlight unit, you need to remove it to access it:
(grabbed this image from an eBay auction to illustrate).
I would remove your ballast first to compare connector types before purchasing the Dorman one as it doesn't look like it has the same connector as the ones I've seen.
Old Jan 7, 2019 | 02:46 PM
hemXF's Avatar
Thank you devetibbs for the reply.
I will surely check before i order.
Thank you
Hem
usmantariq
Mar 5, 2024 07:21 AM
Ubad2
Feb 18, 2018 11:01 AM
denraden1
Jul 3, 2013 12:16 PM
adam699
Oct 23, 2012 01:19 PM
hlgeorge
May 5, 2010 08:29 PM
