Jaguar XF Headlight remove
Old Jan 7, 2019 | 03:51 PM
hemXF's Avatar
Default Jaguar XF Headlight remove
I have a 2013 jaguar XF RWD 6 Cyl, I want to take the headlight unit out of the car. I took out all 3 screws but still i couldn't get the box out. am i missing something? Do I need to remove bumper in order to get the headlight unit out?
I followed below video but this seems to be not working.
Thank you in advance.
Old Jan 7, 2019 | 04:36 PM
OzXFR's Avatar
That video is of the earlier model XF X250, 2008-2011 (also known as "classic"), you have a later model XF X250, 2012-2015 (also known as "facelift") with different headlights and a different removal technique.
I have read somewhere that to get your headlights out you need to not only remove the three bolts but drop the front bumper a little (no need to take it right off), by removing the bolts and screws across the top (under the hood).
Old Jan 7, 2019 | 08:31 PM
2014XFR-S's Avatar
As far as I am aware and having had the bumper off the car at one point, I don't see any way around the headlights being taken out without having to remove the bumper.
Old Jan 9, 2019 | 09:29 PM
hemXF's Avatar
Thank you all for the replace I will try to remove bumper and fix my headlight
Old Jan 9, 2019 | 10:48 PM
OzXFR's Avatar
Removing the bumper was a reasonably easy job on both my 2010 XFS and 2010 XFR, I did it several times and it's nowhere near as scary as you might think, just lots of screws and bolts to remove underneath and on top and a few electrical plugs to disconnect and off it comes. I believe the "facelift" bumper comes off just as easily, my main tip is to have a helper hold one end while you pull the other end away from the bodywork so as not to accidentally drop it.
Old Jan 10, 2019 | 01:53 PM
davetibbs's Avatar
On my 2010 at least, I think it's far easier to remove the rear bolts to the undertray/splash guard that's attached to the bumper, remove the bolts on the top of the bumper, and then remove the bumper and the splash guard as a single unit.
Old Jan 13, 2019 | 12:37 PM
2014XFR-S's Avatar
Yeah, it is fairly simple, just a lot of screws. There are a few plastic screws that have to be removed on the wheel well liners just as an FYI, I believe only 2 per side. IIRC
I will see if I can get pictures from the workshop manual on Monday if that helps.
Old Jan 13, 2019 | 02:01 PM
clubairth1's Avatar
Community Influencer
Just get a helper and put a drop cloth on the floor so you have somewhere to set the cover after it comes off. Very easy to damage the bumper cover when it's off the car.
ExcelsiorZ
Feb 7, 2019 08:58 PM
blasgg
Nov 19, 2017 06:34 PM
hiltoncam
May 26, 2017 01:39 AM
AfricanJag
Nov 25, 2014 12:46 AM
jagosaurus
Oct 3, 2012 01:51 AM
