Jaguar XF passengers headlights bulbs not working
Old Jan 9, 2019 | 09:28 PM
hemXF's Avatar
Default Jaguar XF passengers headlights bulbs not working
Hi all
sometime back my headlamp and ballast burned out and I didn’t replace those yet. But today suddenly the whole lights which are in headlight box are out no signal light no light strip lighting is on. I tried to find out if the fuse is out but in my owners manual there is no fuse number for headlight and turn signal bulbs.
1. Where is the fuse located for turn signal and remaining lights in that light box
2. And my other working light level got reduced and it is only projecting up to couple of yards it use to flash more distance earlier. Do you why would this happen and fix it.
thank you in advance for the help
Old Jan 10, 2019 | 04:51 AM
OzXFR's Avatar
There are no fuses for the headlights in an XF, instead it uses FETs (Field Effect Transistors), which apparently never fail.
It sounds like you have something seriously wrong so your best bet is to take the car to a decent auto electrician and preferably one who has worked on XFs or at least reasonably modern Jags before.
onlypq
Jun 10, 2018 02:27 PM
Kseaborne
Oct 5, 2017 11:28 AM
Bluecortina76
Sep 15, 2017 01:52 PM
xjrjag
Apr 14, 2016 11:57 AM
