Jaguar XF R in 2022
Old Mar 2, 2022 | 03:11 PM
aqura's Avatar
Default Jaguar XF R in 2022
Hi ,
I am thinking of buying a 2010 Jaguar XF R with 54245 miles.
Does anyone know after what mileage (static) the timing chain breaks down ?
I am afraid that I will buy this car and immediately have to replace the timing chain ...
the car cost around 16 k dolars what is a really good price . Jaguar is not really popular car in my country
I would also like to ask if every Jaguar XF R has an R stamp on the dashboard and on the back of the trunk ?
This one is completely devoid of R markings ... Not even air intakes on the bonnet ... But the seller tells me that this is the original with 510 horsepower engine.
Thanks for help ,
Cezar
p.s the photo of this car
Old Mar 2, 2022 | 04:33 PM
OzXFR's Avatar
First of all the pictured car is not an XFR and the seller is lying to you, the bonnet and bumper are not those of an XFR. I had a 2010 XFR so I know very well what it looks like.
It could possibly be an XF Supercharged though, with the same engine (AJ133SC) but detuned from 510 PS to 495 PS, but even then I believe the XF Supercharged also had bonnet vents with "supercharged" embossed on them. If it does have the AJ133SC it is easy to tune to 600+ PS.
The timing chains on the AJ133 can break down at almost any time but they can also last for 100,000 miles plus, it very much depends on using the correct spec oil and religiously changing it at least twice as often as scheduled.
And it's not really the chains themselves that break down, it's the chain tensioners and guides.
JLR updated the tensioners and guides some time in 2014 to a different and more robust design and they changed the design of the chains at the same time (from 6.35 mm pitch to 8 mm pitch and from 9 links to 3) so you can't update just the tensioners and guides you have to update the chains (and cam sprockets) as well.
Anyway if you really want an XFR and not a lesser model of the early XF I would steer clear of that one.
Old Mar 2, 2022 | 07:02 PM
BritCars's Avatar
Agree with Oz. That's not an XFR. It looks like it has the big brakes up front and assuming it is a V8 (?) then it's likely the XF V8 Supercharged. (But check for supercharger...)
The XF V8 SC didn't have bonnet vents, and the front grill and intakes below the headlights look right for that model
It is basically the same car without the body kit. And an almost imperceptible tune difference. So still could be a good buy - but I worry if the seller is mis representing...
50k is pretty low for timing chain issues. But it's a bit hit or miss. And it's a 12 year old luxury car so repairs will be expensive - hopefully you can DIY or are patient and have a good independent mechanic with decent rates?
Old Mar 4, 2022 | 03:35 PM
The_Ikon's Avatar
Based 5.0 SC is detuned to 470 not 495 in the USA …
Old Mar 5, 2022 | 01:38 PM
aqura's Avatar
Hello ,
Thank you for the answer .
Now I know that's why this price is less .
Assuming that this car has 470 PS and the original has 510 PS I think it is not worth to pay extra 3 thousand dollars for XFR version.
I wonder if the car can run on LPG ? I live in Central Europe, where fuel prices have gone up a lot.
I would like to ask . How much does this car accelerate in 0-60 mph ?
The seller wrote that it takes just over 4 seconds to 100 km/h but I don't want to believe him
Have a nice day .
Old Mar 6, 2022 | 09:01 AM
BritCars's Avatar
Yes - lots of reviews when it was launched saw it around 4.3seconds in real life testing. Occasionally a bit quicker but the traction to RWD is probably the limit. XFR seems to run about the same, again suggestion traction is prob the limit. And also highlighting that 470 vs 510hp is a pretty minimal difference in real world driving. I've driven both and cannot tell the difference. Which is why I ended up with the V8 SC as it was a lot better priced when I bought 10 years ago
Note that the 2009 V8 supercharged is a very different engine (4.2L) and meaningfully slower in a 0-60 sprint.
Old Mar 6, 2022 | 10:21 AM
carzaddict's Avatar
walk away from this, the seller is lying to you
Old Mar 6, 2022 | 11:27 AM
User 42324's Avatar
The difference between 470ps & 510ps in real world driving is tiny. Look at the XFR as a trim level.
Old Mar 6, 2022 | 11:15 PM
The_Ikon's Avatar
no….. Run away🏃🏾
Old Mar 10, 2022 | 01:54 PM
The_Ikon's Avatar
So what did you decide to do? Hopefully you’ve got the car that you’re looking for, take your time and buy a true XFR if that’s your desire don’t settle.
Old Mar 14, 2022 | 07:22 AM
aqura's Avatar
Hi,
Sorry for replying so late.
In a few days I will sell my 2007 Audi S5 and buy this car (Jaguar XF 5.0 510 but in reality 470 PS )
Jaguar XF R is too expensive . For me it is not worth to pay extra money if this XF accelerates 0-62 miles in 4.5 seconds ! That is very fast !
When I buy it (in about a week ) I will let you know how it performs .
Have a nice day to all users of this forum !
Old Mar 14, 2022 | 08:47 PM
BritCars's Avatar
Good luck. As I mentioned above, same car I have. Had it 10 years and love it
If well looked after it is very reliable. But I would have it thoroughly checked before buying as issues are expensive to repair
Good luck!!
stivanquasaru
XF (X260)
Oct 7, 2020 04:41 AM
Nick Cowger
Apr 24, 2019 09:16 PM
mbam504
Sep 29, 2015 04:56 PM
