Jaguar xf won't start
Old Sep 22, 2022 | 11:52 AM
skopex's Avatar
Default Jaguar xf won't start
Hello, I have a problem with the jaguar xf 2013 2.2 diesel. The car stood for a few days and does not start. After pressing start, all the indicators light up and no reaction. The pacemaker does not try to crank or make any noise. The message about pressing the brake to start the car normally disappears when you press the pedal. Do you have an idea what it could be? Battery replaced last year. New batteries in the remote control. the diagnostics showed an error P0 512-64 starter request circuit
Old Sep 23, 2022 | 10:38 AM
fivel's Avatar
I don't have the manual for your engine so I can't be specific, but it seems its trying to tell you there is a fault on the "starter request circuit", usually either an open circuit or a short to ground so it can't crank the engine.
Old Sep 29, 2022 | 02:26 PM
RochaSDS's Avatar
Even though the battery has been replaced recently, check the battery connections in the trunk/boot.
I had a similar issue a while back and ended up being the battery connector was corroded and wouldn't make full contact.
Old Oct 2, 2022 | 03:55 PM
Yarnie66's Avatar
Default £2000 later
I had the same problem.. after a local mechanic came everything was pointing to the starter motor.. changed that.. still nothing..changed the brake switch.. nothing.. auto electrical mechanic came out.. fault was that for some reason jag xfs have 2 wires to the starter motor.1 to allow the current to operate the solenoid the other to tell the engine to spin. 2nd wire wasn’t sending a signal so electricalian altered loom to allow the 1 wire to do both.. car has been perfect since
KayC
Nov 14, 2024 10:23 AM
iara_uk
Nov 6, 2024 05:21 PM
Mercedes 1986
Jul 10, 2022 06:09 PM
ecuflex
Feb 24, 2022 02:38 PM
