Jaguar xf250 sportbrake bcm washers issue
Old May 24, 2023 | 01:09 PM
Alyeg3's Avatar
Default Jaguar xf250 sportbrake bcm washers issue
So long storry short i disconected the battery got the key worning and so on,bcm out,virginized programed with jlr ssd.car starts but no washer pump,headlight one works fuses good wires good.what am i missing?
Old May 26, 2023 | 07:38 AM
clubairth1's Avatar
Community Influencer
Have you checked the JB (Junction Box) for corrosion? As you probably know what happens is the washer pump fails and then fluid starts to travel up the wire harness. If this is not caught in time then it causes corrosion in the JB.
Jaguar has a fix so the fluid can't travel up the wires and it's simple. They just added a connection on the middle of the wire so it's not a continuous path from the washer up to the junction box.
Here is a LONG thread from our UK friends that has a lot of details.
Washers Not Working
So first thing is to inspect your washer pump and reservoir. That thread shows you where it is and has several good pictures to help.
Old May 26, 2023 | 07:44 AM
Alyeg3's Avatar
From your reply i shuld understand that you didn’t read,or you didn’t understood my problem.thanks for your time
Old May 26, 2023 | 08:07 AM
clubairth1's Avatar
Do what you want it's your car!
Good Luck!
Old May 26, 2023 | 04:44 PM
sportbrake_phil's Avatar
It sounds like you "virginized" the bcm with an eeprom image from a saloon.
Old May 26, 2023 | 04:48 PM
Alyeg3's Avatar
that would make sense,the only problem is the sdd put everything.the only thing in the mcu was the pflash.the dflash and the eee was completely empty when the sdd got connected
Old May 26, 2023 | 06:26 PM
Did you by any chance dump a copy of the dflash before you started?
Old May 27, 2023 | 01:22 AM
Alyeg3's Avatar
nope,i was not able to read the d flash.i i can get a file that is for sportbrake i can compare the mismatch
Old May 27, 2023 | 04:45 PM
What part number is your bcm? ( the last digit indicates the revision, so I suppose you're looking for an eeprom image from the correct revision )
Could you read the p-flash ok ? ( I'm wondering if perhaps your programmer wasn't connected correctly given you couldn't read the dflash - if that's the case you might not have managed to erase the dflash either, and still be able to get a dump - as those dumps can often be repaired. )
Jag69
Dec 28, 2020 01:31 PM
MussieRon
Jul 12, 2020 11:58 AM
NTL1991
XJ40 ( XJ81 )
Sep 13, 2013 01:00 PM
Selsoft
Jun 28, 2013 07:06 PM
