Join Jaguar Timing Chain Class Action
Old Dec 14, 2019 | 09:18 PM
Jssaab's Avatar
Default Join Jaguar Timing Chain Class Action
Info here
If you are interested in finding out more about this matter or if you are interested in participating
, please contact Gary S. Graifman at (888) 608-9232 or via email at ggraifman@kgglaw.com.
Rockland County, New York
747 Chestnut Ridge Road Chestnut Ridge, NY 10977
View on Map
Bergen County, New Jersey
210 Summit Avenue
Montvale, NJ 07645
View on Map
845-459-0001
Jaguar Class Action Lawsuit
Old Dec 14, 2019 | 10:39 PM
davetibbs's Avatar
Tried it.
They never got back to me, despite my (at the time, what I felt was) valuable experience in tearing the block down and getting photos of damage caused by slack timing chains. Also, note the years that are covered in the class action are only 2012-2014, despite the fact that earlier cars such as my 2010 obviously have the issue.
Finally, unless you're a lead claimant on one of these actions you're likely to end up with a check for the square root of **** all.
Just my 2c
Old Dec 15, 2019 | 07:47 AM
Jssaab's Avatar
Saab put a 8 yr unlimited mileage warrnty on all engines failures due to sludge after a class action. Also extended it beyond all the years in the suit. Better than $$ in hand
I'll give it a shot too on Monday ( I drive through the towns where the office is every week
Old Dec 15, 2019 | 11:44 AM
bmcinsd's Avatar
I have contacted them a few times. Sounds like they are in mediation with JLR which might take some time.
Old Dec 15, 2019 | 12:06 PM
hen555's Avatar
If jaguar had a problem with the engine they would be in big trouble if they didn’t fix it. They use the same 5.0 AJV8 in their new range rovers and f pace svr. Also in the f type.
Problem is most people who buy those new cars buy it on lease and don’t face those issues.
Old Dec 16, 2019 | 12:02 PM
Jaaaggg's Avatar
JLR knows of this problem and have a TSB to fix this on the LR side. It affects 5.0 engines produced from 2010 to 2012 mainly. They changed the timing chain parts for 2013+ JLR cars, so you don't see this ticking time bomb issue on the newer cars.
Old Dec 16, 2019 | 02:28 PM
davetibbs's Avatar
Which makes the fact that the class action only covers 2012-2014 doubly odd.
Old Dec 16, 2019 | 03:24 PM
OzXFR's Avatar
Maybe there is some US consumer law which has a "statute of limitations" such that seven years ago - 2012 - is as far back as you can go?
Although I would have thought this action was being taken under the Magnuson-Moss Warranty Act and I don't think that has a statute of limitations.
Old Dec 16, 2019 | 04:36 PM
davetibbs's Avatar
To be honest, I suspect the years the class action covers reflects the law firm's ignorance about the issue at hand rather than any other reason.
Old Dec 16, 2019 | 06:14 PM
Jssaab's Avatar
Yeah been there, just need to fill in the blanks.
What they will do is discovery and figure all that out ( including Land Rover)
Old Dec 17, 2019 | 09:57 AM
carzaddict's Avatar
I tried to take advantage of that TSB a few weeks ago, and they told me that because my car was out of warranty (2011) I wouldnt quality. is this true?
Old Dec 17, 2019 | 10:37 AM
Jaaaggg's Avatar
Unfortunately yes, TSBs will only be done when a vehicle is under factory warranty. They are not like recalls, so a manufacturer can deny the work. You can use a TSB to call Jaguar NA and raise your concern and they might cover some of the cost, but no guarantee.
As far as I am aware, only LR's had a TSB to address the timing chain issues. Jaguar pretends to be unaware of the issue even though it is the exact motor, except for the oil pan and a few other bits. Is this the TSB you referred to the dealer: https://static.nhtsa.gov/odi/tsbs/20...56266-1292.pdf
Old Dec 17, 2019 | 12:50 PM
Jssaab's Avatar
Seems JLR pretends a lot of times they have no idea. I bought mine used off a dealer across the state and asked about the coupler and the service manager pretended he never heard about it. My dealer locally is the one that told me about the coupler on my XFR and the service manager told me he could hear it going before I could even hear it .Fixed before the warranty was out
Old Dec 17, 2019 | 05:14 PM
hen555's Avatar
If there’s a TSB then should we all do it ? Is it hard for mechanics and expensive for consumers?
If a dealership refuses to do a TSB then must be a risky job or too much work?
Old Dec 17, 2019 | 05:52 PM
davetibbs's Avatar
To clarify, I don't think dealers are "refusing to do a TSB", so much as refusing to do it for free out of warranty.
Old Dec 18, 2019 | 01:42 AM
u102768's Avatar
A Technical Service Bulletin is just technical advice or repair instructions for the dealer technicians to help short cut diagnosis of common issues. Once the car is out of warranty then the costs of any fix would be down to the owner.
Special Service Messages are similar but are more aimed at passing on information to the technicians.
Service Actions cover work that needs to be done to cars next time they come to the dealership for servicing and usually expire after a few years.
Recalls are urgent fixes for potentially dangerous issues and the current owner should have been contacted to arrange a time for the car to be repaired.
Recalls are therefore the only thing that might still be done on an early 5 litre at no cost to the owner.
Old Dec 18, 2019 | 07:32 AM
pab's Avatar
pab
Does anybody know if a similar notice exists for the 3.0 engine?
Current Hers: '13 Lexus ES350
Current Mine: '15 XF (X250) Portfolio AWD
Jaguar - making mechanics out of customers since 1935
Old Dec 18, 2019 | 01:28 PM
croco's Avatar
Are there specified VIN numbers with the affected vehicles? or is it all vehicles up to 2014 year?
I have a 2014 XFR and it is a 2014, I do have certified pre owned warranty till August 2021 but don't want to run it till the engine **** itself.
Any input would be appreciated
Sam
Old Mar 22, 2021 | 05:34 PM
Jonathan Barton's Avatar
Default 2017 fpace
I have fpace from 2017 with 3.0 v6 that is affected only 73,000 miles on odometer Car at dealer now cost is 20,000, hope to have it back in two weeks
Old Mar 23, 2021 | 07:25 AM
hen555's Avatar
Based on my knowledge the timing chain issue affects 2012 5.0L engines and below. If you have this issue with 2013+ engines please advise what the issue is, state your engine and if it is the timing chain guides?
