Jumpstart without access to Trunk
I have a 2012 XF. Trunk key lock seems broken as it won't turn. No access to Trunk. Able to access the cabin through the drivers key (luckily this lock worked).
Looking up online I am thinking to do the following:
- open the fuse panel under the right hand side passenger glove box.
- connect battery charger positive to the positive terminal connected to the fuse panel.
-connect the ground connector from battery charger to metal door hinge.
- hit the trunk release button near drivers steering wheel.
- disconnect battery charger (ground first then positive connection)
- reconnect it to the car battery as similar (positive then ground ) for a jump start.
Does this make sense ? I'm so bad with these things related to the battery.
Going on vacation now. When I got in the car tried starting the engine and then now some lights in my car are flashing as well as a relay noise from under the hood keeps repeating. Also the turn signal lights flashing but very strangely like an error blink very dim. Battery is going to be drained completely when I get back.
From my reading and (admittedly dodgy!) memory that all sounds about right to me.
However I would let the battery charger run for a few minutes first before trying the trunk release, and again when connected to the main battery before attempting to start the car.
But before you go on vacation, do you have time to at least charge the battery enough to get the trunk open? If you do then it would be a good idea to disconnect the battery before you leave (just disconnect the earth lead) and leave the trunk open (or at least lowered but not latched) while you are away.
Is it safe to jump from wheel well terminal and start the engine while it is jacked ? All I have is the basic spare wheel jack nothing fancy.
You will definitely need a new battery if it has depleted for that long
I would not start it on a jack due to risk of rocking and toppling it. I wouldn't jump it with a totally dead battery either. Use the wheel well to get access to the trunk. Then put the car back down and either charge the battery up fully on a charger or replace it if it's really dead. Then start the car
I'm sure you know this but some settings like Trip mileage and maybe radio stations and clock will need resetting. And the window auto open and auto close stop limits (all very easy to do and well covered in the forum)
david i
Feb 21, 2021 09:46 AM
Hex Type
Apr 4, 2015 10:28 AM
rlwpromo
Dec 29, 2012 06:43 PM
