Just bought this cat and it is already driving me crazy,, please help
hey guys/gals
Just bought this 2012 XF 5.0 Portfolio with 53000 miles from a private seller. I inspected the car my self and took it to a dealership for a full inspection. Dealer told me that the vehicle is 100% excellent except a leaking water pump/outlet pipe. I approved the repairs and they called me few hours later to pick up the vehicle.
Picked up the vehicle and everything was excellent. Drove it home (400 miles away) and on the way home I noticed that the radiator cooling fans were going crazy. They were operating at maximum speed. I thought that might be normal because it was a hot day but at 50mph I thought they would be running less than full speed. Anyways got home and shut the car for few hours to let it rest and then went out for a drive because I just couldn't wait till the next day because of the excitement of having a new cat.
Drove it for an hour and everything seemed fine, no fans operating at full speed or anything that seemed unusual. However, at idle (Wether in N, D or P) the vehicle RPMs seem to keep jumping up and down by 100 rpms. There is no check engine light or warnings on the dash just the jumpy idle
Here are the links to the videos I took,, please let me know what you think and if you had this problem before and how did you go about fixing it.
and also
and also
That was the first thing I did except the (drive it like you stole it part) lol. It idled fine at cold start but then when got to normal operating temperature problem reoccurred.
Have the MAF sensors been cleaned (ever)? Either way, it's an extremely easy job to do and there's a write up on this forum. Just be careful not to drop the torx screw(s) into the black hole that is your engine bay. For the life of me, I could not find where mine pinged off to and apparently there is no part number for those screws.
Just curious but thanks for the input
When mine starts to idle less smooth, I always just clean the MAF's and all returns to normal. Takes 5 min. a side max., even the first time. Super easy.
From my own personal experience, I gradually experienced a "rough" idle where I could feel every other-other engine vibration transmit through the chassis which was never present before. The tach was not surging like in your video though and I didn't want it to progress any further, so I cleaned my MAF's and no longer experience said symptoms.
EDIT: Precisely what Kyanite said.
Thanks for the input.
****UPDATE********
My vehicle is at the dealership (different dealership from the one that replaced the water pump and hoses). I got the call yesterday and they are telling me that my cooling fan is out and they are replacing the fan with labor total comes to $1100. I don't know if the previous dealer is to be blamed since they repaired the water pump but overfilled the coolant and the fans been going crazy for the past week.
They are also cleaning the sunroof and lubricating it for $118.
As for the surging idle they are going to check for vacuum leaks and clean the MAFs and see how that goes since they can't find an error code or check engine light.
Ok here is the update,,
I got my car back and I am f***ing pissed. They replaced the fans but still, any time I drive it for longer than 30 minutes the fan would kick on and run on high speeds and never settle until I shut the car off, which I hate because I feel like the vehicle temp is high and one should never shut down a vehicle while it is hot. Although I tend to drive in a straight road at a speed of no less than 45mph for 10 minutes right before I turn in home so it should have had a good amount of time to cool down.
The surging Idle is still there and I am pissed because when I asked my service Advisor said that his tech did not clean the maf sensors.
I don't want to touch it because I payed them to fix the damn thing and they said the would but I got my car and as soon as I got home (85miles away from the dealer) all the symptoms that I took it in for came back.
