Keyless entry issues
Old Sep 17, 2016 | 04:01 AM
pauldohey71's Avatar
Default Keyless entry issues
Hi,
New to the forum so don't know if this an old question, I purchased a 2013 XF 2.2D luxury yesterday and assumed it had keyless entry.exit, it states in the booklet how it works but cant find any sensor on door handle and have to use fob to lock/unlock, does anybody know if this is an issue or does it simply not have keyless entry
Old Sep 17, 2016 | 04:16 AM
jimbov8's Avatar
Paul, with the car locked put the fob in your pocket, walk up to the car door and just pull the handle and it will open.
If you don't want to use the fob when locking the car just press the little black button on the outside of the door handle and walk away.
That's how it works.
Old Sep 17, 2016 | 04:41 AM
Default Wont work
I know thats whats supposed to happen but nothing happens when i walk up and end up having to press the fob
Old Sep 17, 2016 | 05:11 AM
jimbov8's Avatar
Ok, you didn't make that clear in your first post.
Check these 2 fuses.
F13 5A for the receiver and
F30 20A for the keyless entry module.
Both fuses are in the junction box central. If they are ok then you will need to get the fault codes to pin point the problem.
Old Sep 17, 2016 | 09:54 AM
BlckCat's Avatar
Do your handles look like this?
If not then you do not have keyless entry/exit.
On my 2013 XF V6 AWD, keyless entry was part of the Convenience Pack that also included intelligent high beams, electric rear sunblind and auto-dimming external mirrors.
Phantom
UK & Eire
Apr 20, 2017 03:45 AM
JackChestnut
Nov 4, 2016 11:36 PM
mikexkr
Sep 9, 2016 01:26 PM
goldenstitch
20
Sep 6, 2016 06:43 PM
S-TYPE06
Sep 3, 2016 08:15 AM
