Mileage verification
Old Jun 24, 2011 | 01:13 PM
VetteOwner's Avatar
Default Mileage verification
Looking to buy a used XFR but wanted to know if there was a way to verify the mileage shown on the odometer display? OBD possibly?
Old Jun 24, 2011 | 04:26 PM
Fraser Mitchell's Avatar
Depends how old the XF is. The service records should give some idea and also show if the car has been taken care of. I would expect to see at least a service invoice with the mileage on it for each full year since car was registered for the road, more if it is a high miler. No service records would make me think somebody wants to conceal something
Old Jun 25, 2011 | 12:45 AM
hlgeorge's Avatar
The XF series should have a complete Carfax info, especially concerning mileage. A dealer could also look up the service history with the owners permission.
Old Dec 13, 2011 | 10:53 PM
AvechuchoAxel's Avatar
If you have access and you can remove the instrument cluster, look closely at the BDM pads for some rest of melted resin (brownish) and look also for a solder points along the board that not looking as the same along the board. This can not give you the actual mileage of the vehicle, but for sure it's a indication that the mileage was altered. Not always this happens because a rolling back business was done on the vehicle, but a used swapped cluster will never match your mileage and need to be adjusted. I did fix a lot of cluster with stepper motor problems, fading displays, etc, but is more common that the customer just replace the cluster for a used one. Programming and immo issues is another story....
Axel
rominempire
28
Oct 8, 2020 10:39 AM
hoodun
Oct 2, 2015 02:06 AM
hoodun
Oct 1, 2015 07:46 PM
Malihide
Sep 29, 2015 03:21 PM
