Motor mounts
Old Jan 2, 2016 | 07:52 PM
Ness925's Avatar
Default Motor mounts
HAPPY NEW YEAR FAMILY
when i step on gas i feel the left side of car lift up most likely motor mount has anyone had theirs changes and approx, how much.
09 xf/sc
thx
Old Jan 4, 2016 | 12:46 PM
tbird6's Avatar
Please check that it is bad before replacing anything. Here is an old shade tree trick which will show you if the mounts are bad or not in about 5 minutes.
Open the hood of the car, get inside and start the engine. Now put it in gear with your foot on the brake. Slowly increase the gas like you would if power braking the car. Now watch what the engine is doing in the engine bay. As the torque builds you will compress one mount and apply tension to the other.
Does the engine raise up very much?
If not put the car in reverse and do the same thing. We are now loading the mounts exactly opposite of what we just did.
Now does the engine raise up?
If either mount is broken there will be no doubt about it using this test.
You can't go by what the car is doing. Just too many things involved and your feelings are not calibrated either.
rcollum
US Mid Atlantic
67
Dec 31, 2016 02:56 PM
andrew lowe
Jan 6, 2016 12:58 PM
retriever-007
Jan 4, 2016 04:29 PM
InverStype
Jan 1, 2016 09:30 AM
InverStype
UK & Eire
Jan 1, 2016 06:02 AM
