Multiple Electrical Issues
Old Mar 29, 2019 | 11:34 AM
Shaunymc's Avatar
Question Multiple Electrical Issues
Hi All,
I'm not new to the forums but have not posted before, so any help is appreciated.
I have a 2012 XF S Prem Lux (S/S). Third Jaguar, 2nd XF....I just don't learn :-)
This one has developed a few niggles.
1. Sat Nav has the familiar reset to Belgium and keeps endeavouring to 'initialise'.....works when I don't need it...But is obviously intuitive and won't work when I do need it
2. Start / Stop has a mind of its own..'nuff said' ! (Plenty about this on the boards..
3. Air con has decided to stop...this was not gradual (i.e. indicating gas loss)
4. DAB Radio Station Presets often not visible when the radio initialises.
Not electrically related....but I also have rattling drivers door!! Slightest tweak down of the window solves prob...I think its the seal on the door at the very top corner.
The electrical bits, I suspect, must have a common failing, either that, or I'm just unlucky....
The rattling door...same as the 2008 2.7 Prem Lux I had!!
Finally, I dont agree with the red squiggly lines....'endeavour' does have 'U' and 'initialise' an 'S'.....
Thank you in anticipation for your time and any response.
Regards
Old Mar 29, 2019 | 03:30 PM
A very delayed "welcome" to the forum Shaun as I can see you have been with us for more than three years.
The commonest cause of weird electrical phenomena on modern Jaguars is a failing or partially discharged battery. Wherever troubleshooting leads you, this should be checked and eliminated as the first step.
Old Mar 31, 2019 | 08:03 AM
Shaunymc's Avatar
Thank you for the kind welcome and advice.
I have a friend with a Diagnostics Kit and will plug in later.....
I'll post the results.
Regards
Shaun
AndrewG
Nov 4, 2018 01:00 PM
MikeofBonsall
May 29, 2018 10:29 PM
Satansedan
Aug 1, 2015 08:06 AM
comcaller
XJ40 ( XJ81 )
May 24, 2010 09:11 PM
FloridaXJR
Dec 26, 2009 10:40 AM
