MY 2012 XFR Front Caliper Pin Size
Old Feb 7, 2016 | 04:28 PM
sparkenzap's Avatar
Default MY 2012 XFR Front Caliper Pin Size
I finally got around to changing the front brake pads on my XFR. All of the write- ups I have read for XF brake changes say the caliper pins are 9 mm hex. The ones on my car are not 9 and are bigger than 10 but apparently smaller than 12. I do not have an 11 mm hex driver (yet!). Can anyone confirm that the caliper pin has indeed got an 11mm hex head?
Old Feb 7, 2016 | 05:20 PM
OzXFR's Avatar
Mine (2010 XFR) are definitely 9 mm hex, never heard of any other size on any XF, including 2012 - 2015 "facelift" models. Something strange going on!
Old Feb 9, 2016 | 06:04 PM
Bigg Will's Avatar
Same here?
Old Feb 11, 2016 | 04:58 PM
sparkenzap's Avatar
Thanks, guys
Indeed, I just "missed the hole" with the 9mm hex wrench. There is an inside shoulder that I did not expect and I was feeling that when I tried the 10 mm socket. Back in the old days when I could see, I might not have made this mistake!
Only additional comment is that, like other posters, after the rear brakes were down to 4 mm pad thickness and cut the sensors, the fronts are still 6mm or more thickness.
Terry007
Sep 1, 2017 12:19 PM
mhenz
Mar 11, 2016 04:57 PM
Pilotman11
Feb 6, 2016 06:19 AM
Broken_Spanners
Feb 1, 2016 09:28 PM
