Navigation appears to be missing states
Old Sep 13, 2011 | 08:22 PM
Jaguaristi's Avatar
Unhappy Navigation appears to be missing states
Here is an oddity: I went to create a stored memory point in my 2009 XF today and tried to change the "search area" (i.e. state) to Iowa.
However, it does not appear that "IA" is an option, and then I noticed other states are "missing" as well.
Is there a second disk I should be looking for? Is this a system setting of some kind I should turn on.
Help?!
Thanks.
Old Sep 13, 2011 | 09:30 PM
cwood's Avatar
i had a nav cd case with two discs. Betting you need to switch discs.
Old Sep 14, 2011 | 09:16 AM
Brutal's Avatar
yes there a 2 discs
Old Sep 14, 2011 | 09:09 PM
Jaguaristi's Avatar
I'm sure I don't have the second one, but I'll look. Anyone know the best replacement source for getting either just the disk I need or both disks?
Thanks.
Old Sep 15, 2011 | 12:58 PM
Jerry S's Avatar
Thanks.
Don't know the year of the disc that you have, but the 2009 MY Nav needs to have the 2010-2011 discs installed. They correct a software problem that caused the Nav system to malfunction when traveling on restricted lane roads. You can order the disc set through Jaguar NA, Navteq, or a dealer for $199
Old Sep 16, 2011 | 08:17 AM
Jaguaristi's Avatar
Jerry - thank you for that. I will go out and look right now. Here is a newbie question --- with a two-disc set do you literally have to pull over to the side of the road and switch discs when you go into a state on the other disc? Do both discs load simultaneously?
How does a 2-disc system work?
Thanks.
Old Sep 17, 2011 | 10:39 PM
CP1's Avatar
CP1
In 2011 it's a single slot nav DVD reader. You have to change discs manually. You can't load 2 DVDs. On the plus side, there is some overlap of the coverage areas between the 2 DVDs.
way2far
Aug 31, 2022 09:26 AM
johndahlheimer
Sep 16, 2015 05:44 PM
neckstrap
US Western
Sep 10, 2015 10:44 PM
tberg
Sep 7, 2015 07:32 AM
