No responsive fuel pump
Old Jan 3, 2025 | 09:55 AM
Rique's Avatar
Default No responsive fuel pump
After my V8 NA engine swap motor run perfectly after some issue like non charging alternator. After I fixed that my fuel pump is not sending fuel. Other than a bad or dead pump which I find highly unlikely is there
any issue related to engine swap that mite be causing no response or is this just standard electric faults, fuse, connector, bad pump etc
Appreciate the comments.
Old Jan 3, 2025 | 10:19 AM
clubairth1's Avatar
Community Influencer
Which fuel pump? What codes does the car have?
What code reader are you using? If not SDD you might not be seeing all the codes.
98Jagxjr
Jul 6, 2024 05:24 PM
Josh Nichol
Apr 29, 2024 01:36 PM
plums
General Tech Help
Jan 17, 2016 02:28 AM
Robochop
Nov 17, 2014 07:25 AM
matjohns
Sep 15, 2011 08:48 PM
