No start no crank dead cluster no communication
Happy new year from South Sudan.
I found this Jaguar that has been parked for the last two years, at a garage in juba, the issue that brought it, was the gear knob refusing to pop up, due to lack of skilled electrical knowledge they have replaced the whole harness, I have seen two lock sets, as in bcm, rear fusebox, engine ECU, rf receiver, and another gadget on the left side of the trunk, but still it hasn't started for two years, I came to juba just a few weeks ago.
I was handed another lock set yesterday and told to attempt to start, I plugged in the new lockset, but couldn't turn it on even with the new key, but when I went to the immobilizer to see if I can programme the key, it turned on the cluster just for a few seconds and went off again, I was able to see two keys and I added the new key( from lock set) to the car but still it wouldn't turn on or start, it kept displaying that it can't find the key,
This is my first Jaguar. I was able to scan everything apart from ECU and trans module. Can you help with pointers please. This car needs to run, she belongs on the road
Copied from a FB group, but might be of help with getting the ignition to turn on & enable you to run immobilisation with SDD.
Jaguar XF remote lock/key not recognised issues.
I've been getting many requests from the group via word of mouth and I've done quite a few.
Issue one most common:
Car won't lock after battery disconnect. This is solved via immobilisation in SDD.
Issue two less common:
Key not recognised at all hence no ignition, immobilisation not possible.
This is done via cluster reprogram as it will bypass the key sequence, turns ignition itself and do the immobilisation at the end.
This will also update cluster to latest software, bonus.
Please don't throw suitcases of money on KVM module/keys and what not, I've never seen a faulty KVM module.
Daim
Apr 8, 2020 05:05 PM
