overhead map light turns on by itself on bumps
Old Aug 22, 2016 | 04:27 PM
carzaddict's Avatar
Default overhead map light turns on by itself on bumps
The overhead map light keeps turning on when i hit a pot hold. I know this is a common issue for XF's....i had the same issue on my 2009 XF. but at the time I never did anything about it.
how can I fix it?
Old Aug 22, 2016 | 06:22 PM
OzXFR's Avatar
Easiest way to fix it is to replace the globes with white LEDs, which will also give you the added bonus of much nicer light than the stock sickly yellow globes.
Plenty of threads around here on how to do it.
One added hint - the globes sit in globe holders which twist in and out of the housing, and those globe holders have a pair of "tangs" on the back which connect up with a ring on the housing to form the circuit. Sometimes those tangs have been bent out just a tiny bit and they don't connect properly, the fix is to gently bend them back in a little bit.
Old Aug 22, 2016 | 08:38 PM
carzaddict's Avatar
thanks! actually replacing the bulbs with white LED's is usually the first thing i do when i get a car. i even know where the thread is for what bulbs i need
andy.buxtonxf
Apr 21, 2016 11:44 AM
bryce804
Apr 19, 2016 03:37 AM
Rhett
Apr 6, 2016 08:03 AM
dragudo
Mar 28, 2016 04:44 PM
BertR
Aug 16, 2014 07:57 AM
