P0088 High Fuel Rail Pressure
Old Jun 8, 2022 | 08:48 AM
2011_XF_5.0's Avatar
Default P0088 High Fuel Rail Pressure
What would cause this code? I’ve already replaced both HPFP, vacuum pump, low pressure pump, in tank filter, fuel rail pressure sensor, low pressure sensor behind the wheel well and 4 injectors on the bank in question. I cannot get this stupid code to go away. Throws this code within the first 15 seconds of a very rough cold start, 3,800 RPM comes down to normal idle and restricted performance light comes on as well as a noise that SOUNDS like timing chain but is not. Noise is most prominent at HPFP cam and in the fuel lines coming from the pumps. 2011 5.0 with 58,000 miles. https://youtu.be/Ich5xhxcAU0
Old Jun 15, 2022 | 02:35 PM
kansanbrit's Avatar
Probably ecu. I had one that was throwing cam timing fault all the time. Changed it, fixed it. But could also maybe be that your fuel pump cam is out of time because that chain is loose?
Old Mar 29, 2026 | 08:10 PM
puzon23's Avatar
Have you ever found out what the issue was?
bmcinsd
Jun 3, 2025 07:57 PM
2011_XF_5.0
May 4, 2022 04:36 PM
Cello5887
Jun 22, 2019 11:57 AM
darrellleece
Aug 16, 2017 07:22 AM
