P0442 error after gas cap loose
Old Apr 3, 2019 | 07:33 PM
pnguy28's Avatar
Default P0442 error after gas cap loose
So my wife forgot to tighten the gas cap and got a message on her dashboard. I don’t remember the exact message but it’s something like “something fuel cap?” I don’t recall but I told her to check the gas cap and see if it’s tight. She stopped the engine, tighened it, then started the car again. That message on the dashboard is gone but now the check engine light is on. I figured the check engine light being on is related to the recent gas cap loose issue.
I read on here that the light will turn off after a few cycles. Well it’s been 4-5 days now and the light is still on. Took my car to autozone and their code reader reported p0442, p0402, and p057b.
Can anyone help?
Old Apr 4, 2019 | 03:57 AM
JagV8's Avatar
2 of those are shown by a web search as not to do with the gas cap so maybe there are actual faults...
Old Apr 4, 2019 | 07:13 AM
pnguy28's Avatar
do they go away after some time?
Old Apr 4, 2019 | 08:51 AM
JagV8's Avatar
Only if not current.
Old Apr 11, 2019 | 06:48 AM
Bigg Will's Avatar
P0402 is the gas cap, once corrected it should go away on its own.
P057b relates to the brake pedal position, and is likely due to a faulty brake light switch, it won't go away, even if fixed until commanded to by a dealer level scanner after being repaired. But it doesn't turn on the check engine light.
P0442 Relates to the EGR valve allowing too much flow, it will turn it's fault off after repair.
jimlombardi
May 9, 2019 08:17 AM
englevakten
Jul 14, 2018 02:28 PM
1964Daimler
Sep 8, 2015 11:54 PM
daro31
Aug 27, 2015 09:26 AM
Oct 28, 2010 11:12 AM
