park brake fault. Replace parking brake motor,cannot clear fault code. Please help.
Old Oct 2, 2017 | 10:05 PM
auto4ce's Avatar
From: 176 Sin Ming Drive #04-07 Sin Ming Autocare Singapore 575721
Default park brake fault. Replace parking brake motor,cannot clear fault code. Please help.
Jaguar X250 XF (2012)
Old Oct 3, 2017 | 12:02 AM
Mr Sharky's Avatar
I believe that you need to do that with the SDD software. Your independent repair shop or Jaguar dealer should be able to do that.
Old Oct 3, 2017 | 01:36 PM
Qvhk's Avatar
Back tracking a little, how sure were you that the parking brake motor was really the cause of the "park brake fault". Low battery and poor connector contact can sometimes jam the parking brake. Not sure if the XF has the same set up as the X350. In the latter, the system resets itself automatically, guiding you by dash messages, once you disconnect and reconnect the parking brake motor.
jomo
Aug 20, 2017 02:38 PM
erc1234
Aug 16, 2017 02:59 PM
Jagernaut
30
Aug 17, 2014 05:47 PM
peyot
Jun 21, 2011 06:04 AM
