Pedestrian system fault
Old Feb 20, 2018 | 01:56 PM
PaulM's Avatar
Default Pedestrian system fault
I keep getting a pedestrian system fault warning. The system isn't activated the bonnet not raised. Anyone else had this same issue? Told by dealer that in very low temperatures the sensors can freeze and should be ok once thawed but it's 9degree so not frozen. Goes out when I restart the engine and then comes on at random and doesn't go out until I stop and restart the engine.
Any help appreciated.
Old Feb 20, 2018 | 03:48 PM
OzXFR's Avatar
I read somewhere recently (this forum, a different one, not sure) that the pedestrian system keeps count of "near misses", ie bumps which don't quite set off the pedestrian airbags (potholes, speed humps taken a little quickly etc etc), and after a while the count "overflows" and you get the warning you are getting. If so, you need to get that count reset and IIRC the only way to do that is to have a JLR dealer connect up their SDD equipment. Also, the excessive count could be caused by a dodgy / too sensitive sensor.
moar
Jul 31, 2025 01:12 PM
Redescape
Jul 13, 2020 07:59 AM
Per
Feb 12, 2018 12:42 AM
jimboire
Oct 26, 2014 02:32 PM
stubbdog
Jun 11, 2014 04:56 AM
