Possible source for metal version of rear coolant crossover pipe for 3.0 SC
Old Apr 13, 2024 | 04:39 AM
Asfc's Avatar
Default 5.0 metal coolant crossover pipe
Found one!! The elusive 5.0 upgrade.. I was planning on purchasing a 3.0 seamless pipe and cutting it down and re-welding/brazing but I finally found a 5.0.
I hate the 2 piece construction though.. going to remove gasket and running a bead around the outside/braze.
https://euro-amp.com/collections/jag...302bbf9d&_ss=c
Old Apr 13, 2024 | 09:43 AM
clubairth1's Avatar
Community Influencer
Hey, hey, hey you found it!!
Many thanks for that as we have been waiting for the rear water manifold in metal for the 5.0L engine. Great that it fits the SC and NA models too.
Also on EBay for $200.
Rear Water Manifold-5.0L Engine
Just ordered it too! This was the missing piece we needed.
Old Apr 13, 2024 | 01:07 PM
bydand's Avatar
Old Apr 13, 2024 | 04:43 PM
Asfc's Avatar
Hey your link doesn't work, care to resend?
Old Apr 14, 2024 | 06:48 AM
clubairth1's Avatar
Yes here is the EBay part.
Rear Water Manifold
The Aliexpress one is way cheaper so I hope it works out. $57 compared to $189!
Old Apr 14, 2024 | 10:23 AM
bydand's Avatar
Rear Water Manifold
I,ll let you know, I do intend to open up, reseal, change the securing screws and test.
I have now ordered the alloy Thermostat housing also.
https://www.aliexpress.com/item/1005...23991802SfCGHu
Old Apr 14, 2024 | 12:44 PM
clubairth1's Avatar
Yes after what we saw with several of the 3.0 versions the QA is lacking BUT it seems the basic part is OK.
Old Apr 15, 2024 | 04:03 AM
  #28
Nansan21's Avatar
Looks like a fully cast version is available in the v6 version on aliexpress. I just purchased one to see what the workmanship is like.
Already have the 2 piece ( with screws to compare)
Old Apr 15, 2024 | 09:25 AM
clubairth1's Avatar
Interesting! So we have two versions to choose from? One with a split housing using screws to hold it together and now a single cast part.
Yes please post back and that was a good find!
Old Apr 15, 2024 | 09:38 AM
  #30
bydand's Avatar
https://www.aliexpress.com/item/1005...Cquery_from%3A
sure looks like it. Interesting to check the cw flow through the ports.
Old Apr 15, 2024 | 09:46 AM
  #31
clubairth1's Avatar
Man that looks so factory! Comes in a JLR bag with the green round symbol? Even says made in UK and "genuine"?
Is it a factory part?
Old Apr 15, 2024 | 09:51 AM
  #32
bydand's Avatar
AliExpress, They only sell 100% OEM, Original Copies! Cheap!! What could go wrong.
Old Apr 19, 2024 | 05:27 PM
  #33
Zigilburk's Avatar
EuroAMP has a full kit to replace all the problem plastic cooling system parts.
I am going to have everything replaced in 3 days.
https://www.ebay.com/itm/226059765612
Old Apr 24, 2024 | 08:49 AM
  #34
bydand's Avatar
Default AJ133S and AJ133NA Rear Heater manifold in Alloy
and So it was. Shiny on the Outside and another word beginning with S on the inside. Read (Polished Turd) I could of-course have been unlucky.
Well packaged.
Sealing rings a little close to the flange faces, with about 0.5mm raised proud of the flange face.
A water test to clean flush in the sink and showed the ports and opening were flowing (some) water.
A little more in-depth investigation with the duel camera endoscope revealed the hidden depths.
Much the same comments as that posted above on the 3.0SC rear heater manifold as detailed above. see post No.13
Flashing build up internally on the port connections and the manifold. The heater out pipe being the most obstructed.
Unfortunately, I was not able to pry it apart and inspect both insides of the manifold for internal inspection, so boxed up and sent back for refund.
Having two plastic rear AJ133S heater manifolds in stock.
The inlet port legs RH & LH on the alloy manifold were 6mm bore, while the Plastic manifolds were 12/13mm. Granted the CW is only going to exit out the 6mm vent return, and/or through the heater marix outlet pipe, ( if it was unblocked)
But still too easy to additionally clog/block the leg ports in my opinion.
Sure, you could drill it all out, and make it correct once fully inspected, But since I have two plastic manifolds already, and need the money for other parts I'll pass.
Would still be interest in someones internal inspection of the one piece rear manifold.
see Pics.of the two piece Alloy rear manifold.
Fresh Out the Box
Makers Logo
Makers marks on bottom of vent outlet port chamber.
The sealing rings are not very proud from the sealing face, compared to the plastic header pipe. 0.5mm to 1.5mm Looks more like an O ring rather than the square section sealing ring of the original.
RH internal leg port to the rear manifold.
Outlet to Heat matrix from the rear manifold
more of the same. About a 6mm Dia hole in the 13mm outlet line bore.
Yes it probably would work if you cleaned out the inlet and outlet ports and enlarged the holes, But...
Old Apr 24, 2024 | 10:03 AM
  #35
clubairth1's Avatar
Good work and pictures! Thanks again for a real world report as I have the metal version sitting on my bench right now.
It will be inspected before I consider installing it.
Did not realize the factory plastic rear water manifold used square sealing rings and not O-rings?
Old Apr 24, 2024 | 03:56 PM
  #36
Six Rotors's Avatar
Did not realize the factory plastic rear water manifold used square sealing rings and not O-rings?.
The one on my shelf has O-rings, it is called heater pipe and part no is AJ812458 and the O rings are called water outlet seals, cylinder head, and part no is AJ811600. These for 5.0L engines. ( Yes I bought them four years ago just after I bought the car expecting to need them and before the metal pipes became available)
Old Apr 25, 2024 | 01:14 PM
  #37
clubairth1's Avatar
Thank you for the seal part number. I purchased my metal rear water manifold from Eruo-Amp and yes I paid about $190 for this one. Took it apart and then checked for flashing and casting debris. This thing is spotless inside. Hard to separate and I wish I knew what sealant Euro-Amp used so I can put this back together.
Checked all the passageways with a small light and they are all clear.
I do think the comment about these pictures looking like some kind of Colonoscopy are correct!
Thanks for the description of the seal (AJ811600) too and the Euro-Amp one does have a sealing ring that is square on the bottom and round on the top where it mates up to the engine.
Sorry this one is a bit blurry but it is round on top.
This is the bottom and it's square.
Happy with what I found but still glad I took everything apart to check after the reports we have seen so far.
Old Apr 25, 2024 | 02:17 PM
  #38
bydand's Avatar
What is the internal dia of the inlet leg ports from the cylinder heads, into the manifold, please.
Old Apr 26, 2024 | 08:32 AM
  #39
clubairth1's Avatar
Sure can!
Hope this helps.
Old Apr 26, 2024 | 08:45 AM
  #40
bydand's Avatar
0.44 in = 11.176 mm, All the way through bore to the leg elbow? Is what I would be expecting, from each inlet leg. And the discharge outlet to the heater matrix Dia 13mm and the 6mm vent port.
I was getting 6mm bore! in these inlet legs. Which was another concern with mine.
cheers,
