Power Steering
Old Nov 12, 2014 | 06:30 PM
acxzxca's Avatar
Default Power Steering
So I realized that I have a problem with power steering and I figured out after calling many maintenance shops that it is a power steering fluid problem. I checked the fluid and it is below minimum. I also checked the ground and it is slightly wet in a small circular area even when it was 0 degrees outside. It also smelled. How much do you think it will cost to repair if the hose needs replacement?
2010 XF Jaguar. 48000miles.
Old Nov 13, 2014 | 09:47 AM
BritCars's Avatar
Are you sure it's the hose? I had a leaking power steering pump on my 2010 XF SC. Apparently not an unusual issue (not as common as the water pumps which fail often). Fortunately CPO warranty covered it, so I can't answer your actual question on cost. If it's just a hose, buy the part and get an independent specialist to fit it - am sure it will be cheaper... But worth checking that the pump itself isn't leaking first..
Old Nov 19, 2014 | 07:13 PM
CP1's Avatar
CP1
Originally Posted by acxzxca
... How much do you think it will cost to repair if the hose needs replacement?
[Carl Sagan] billions and billions [/Carl Sagan]
Bcrary3
Sep 26, 2015 10:36 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
1964Daimler
Sep 9, 2015 11:28 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
