Question on instrument cluster change
Old Oct 20, 2021 | 04:55 AM
garysaunders85's Avatar
Yes it used to work without being in the keyport. Sometimes it still does, which is very confusing
Old Oct 20, 2021 | 05:39 AM
Bigv's Avatar
Something in your pocket shielding the signal?
The coil in the receiver breaking down?
Main car battery needing charged?
I’m guessing now…
Old Oct 20, 2021 | 05:51 AM
Car battery checked out okay.
No interference with anything in the pockets.
I've changed the batteries and also messed with the prongs on the inside of the key fob.
Old Oct 20, 2021 | 06:55 AM
litteredwithfaults's Avatar
Either the fobs are not broadcasting a radio signal, or the modules and cluster are not picking it up, or even looking for it. Unlikely both fobs suddenly quitting at the same time so it could be just the car being senile. This would be funny if the dealers didn't play dumb and default to telling people to fork over 5k to fix it.
If you have SDD, you can try running some security service functions. Read this whole thread.
https://www.jaguarforums.com/forum/x...3/#post2069153
Old Oct 20, 2021 | 09:43 AM
clubairth1's Avatar
Community Influencer
I don't even attempt to swap the transponder over from the old key. I have always got a new transponder with a new key FOB and programmed them as new keys using SDD.
I think Bigv is correct and there is still some confusion about the FOB .vs. the transponder? As Bigv said the buttons on the FOB have nothing to do with starting the car. The FOB is really 2 separate items combined into one. A small battery powered transmitter to lock/unlock the car and a passive transponder chip waiting to be signaled by the car start sequence.
Yes the transponder should really never wear out as it's just a passive device but it's easier to buy a complete unit.
car5car
Oct 16, 2023 11:42 AM
jaychalmers
Jan 31, 2020 07:48 PM
max224
Sep 23, 2018 01:20 PM
MirGr
XF (X260)
Mar 16, 2018 01:59 PM
warrjon
Nov 25, 2017 03:09 AM
