Radar detector/ cigarette lighter question
Old Feb 13, 2014 | 12:25 PM
RoswellJAG's Avatar
Ok, for those this may help. I just finished this little project. I mounted my Audi Blendmount which works for the XFR along with their 12" Mirrortap for power. Remove the shell behind the mirror. Unplug the connector in order to handle it more easily. You will tap the black wire for ground. I did not have a brown/yellow like Chuck so I had to look for the switched power. It turned out to be the wire next and to the left of the black when the connector is plugged in. Sorry but I forgot to write down the color of the wire and realized it after all was put back together. In any case it took a couple of minutes to find it via trial and error. You can also try a voltmeter.
By the way, this is much easier and quicker than fiddling with the overhead console as long as you use one of these power tap-type wires.
Good luck!
Old Feb 13, 2014 | 02:02 PM
chuckh007's Avatar
Hey….good work…..can you send me a photo of the Blend-mount so I can see how it compares to what I have ? I did send you a photo of my mount but I guess you lost that too. I wish I could attach jpg to these messages…..but can not figure it out.
Old Feb 13, 2014 | 03:07 PM
Darren2012's Avatar
Default Well done
If you can share more info on how did you take it apart without making damage to the whole thing.
The more info the better.
Thanks.
Old Feb 13, 2014 | 03:31 PM
RoswellJAG's Avatar
Originally Posted by Darren2012
If you can share more info on how did you get it apart without making damage to the whole thing.
Thanks.
You just squeeze it at the seams and it literally flies apart. It doesn't break but be ready to catch it. LOL!
Old Feb 13, 2014 | 03:52 PM
RoswellJAG's Avatar
Old Feb 13, 2014 | 06:45 PM
chuckh007's Avatar
Thanks…….by clicking on the "Original Link" the image is better and clearer and larger. I did not have that much room on the stem between the mirror and back mount, so I figured any Blend-mount would not work…..saw that you used the Audi model.
Old Feb 13, 2014 | 07:24 PM
RoswellJAG's Avatar
Yeap, its their mount for Audi, aud-002/bbe-2025. Very thin at the mounting point.
Old Mar 12, 2014 | 10:00 AM
  #28
RodTee XF's Avatar
Thanks Chuck & Roswell I installed my Safe-n-sound stealth cord 2 days ago with you guys help from this post. My ignition switched +12v was brown & yellow but as stated the "needle" connections made this very simple to do. Thanks again!
Old Mar 12, 2014 | 08:39 PM
RoswellJAG's Avatar
You are quite welcome. Glad I was able to give back to our community.
redgear
Sep 18, 2015 10:05 AM
SeanU
Sep 18, 2015 08:09 AM
cyber3d
Sep 15, 2015 02:37 PM
DustysSon
Sep 13, 2015 04:17 AM
jagent
Sep 12, 2015 01:40 AM
