Radiator fan not working - engine overheating
Old Aug 23, 2023 | 04:56 AM
AlbertWeeda's Avatar
Default Radiator fan not working - engine overheating
Hello,
i am currently on holiday in Austria and visited several garages to fix my little problem but no garage has eother time or knowledge to get it done. It seems many garages are affraid of jaguar somehow…
i would like a quick fix/workaround so i can go to
my garage in the Netherands next week. So i was thinking of connecting the radiator-temparaturenswitch wires so that the fan is always on adn i can drive home. It is just that the radiator is packed and i cannot reach it so then i was thinking maybe i can manipulate the relais in the fuse box so that it is always on. But i cannot find which relay is for the ventilator. There is no schema for the relays in the user manual only for the fuses.
does enyone know which relais is for the ventilator?
Old Aug 23, 2023 | 05:03 AM
Robtrt8's Avatar
The "relay" is part of the fan module which is part of the fan. The whole thing needs replacing. There must be a JLR or Ford dealer in Austria that can get you a new radiator fan?
Old Aug 23, 2023 | 03:16 PM
Bigv's Avatar
I think, but I’m not too sure, that if you unplug the temperature sender, the fan should run continuously. Some sort of default
Old Aug 27, 2023 | 07:59 PM
dennis black's Avatar
First check the fan works independently, because alot of time it's the thermostat ,the thermostat should reach 203 degrees then let coolant run through the engine,and when the coolant gets to hot ,it turns on the fan, when you turn on the Ac does the fan turn on
hjanac
May 16, 2025 07:46 AM
Marcin Wasilewski
Mar 8, 2023 04:14 PM
Supercharged81
Jul 20, 2021 07:19 AM
mikega
May 12, 2021 02:38 PM
BALTVISTA
Oct 1, 2009 05:33 PM
